redline 10w-40, $168 for 3.8ltr
i would not follow what the manual says as we are in Australia and not japan so the oil preforms differently. You will need a thicker oil than 5w-30 because you will get unwanted engine wear over time. Best weight is 10w-60
the only reason i have 10w-40 in my car is because its only one 453km ...... literally. don't go thinner than this.
https://www.sau.com.au/forums/topic/270784-oil/#findComment-4623241
redline Lightweight shockproof has probity saved my gearbox. I dont care is cost more than gold my gearbox stopped being clunky and made it feel new again :)
ended up making every single part in my car that needs oil being redline oil and dont forget the coolant :)
https://www.sau.com.au/forums/topic/270784-oil/#findComment-4623441
  • 1 month later...
The reason for not using a thin oil on an older engine is because of the engine bearings ...
if you use a thinner oil it increases the possibility of you spinning a bearing
just like in a used differential it is unwise to change diff oil with old bearings ... as when you add fresh oil with old bearings they fail
https://www.sau.com.au/forums/topic/270784-oil/#findComment-4732459
whats every ones thoughts on using penrite hpr 15 0nce i flush my oil? also iv been told if i use the shorter z170 filter instead of the longer z115 (both do fit the z115 is the standard recomendation for a c210 the z170 for the r30) it will boost my oil pressure slightly witch makes sence to me but is this a bad idea in an engine 28 yrs old with almost 170 000 km on the clock? any ideas would be greatly apreciated
https://www.sau.com.au/forums/topic/270784-oil/#findComment-4733715
where when n how much do i need to buy
i been told to use penrite hpr 15 but im gona flush it with crappy gtx first
http://www.skylinesaustralia.com/forums/Ma...Gr-t276540.html
just pm me if ur intersted
i use it in my 34 and i wont touch anything else at all anymore
https://www.sau.com.au/forums/topic/270784-oil/#findComment-4734386
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
