redline 10w-40, $168 for 3.8ltr
i would not follow what the manual says as we are in Australia and not japan so the oil preforms differently. You will need a thicker oil than 5w-30 because you will get unwanted engine wear over time. Best weight is 10w-60
the only reason i have 10w-40 in my car is because its only one 453km ...... literally. don't go thinner than this.
https://www.sau.com.au/forums/topic/270784-oil/#findComment-4623241
redline Lightweight shockproof has probity saved my gearbox. I dont care is cost more than gold my gearbox stopped being clunky and made it feel new again :)
ended up making every single part in my car that needs oil being redline oil and dont forget the coolant :)
https://www.sau.com.au/forums/topic/270784-oil/#findComment-4623441
  • 1 month later...
The reason for not using a thin oil on an older engine is because of the engine bearings ...
if you use a thinner oil it increases the possibility of you spinning a bearing
just like in a used differential it is unwise to change diff oil with old bearings ... as when you add fresh oil with old bearings they fail
https://www.sau.com.au/forums/topic/270784-oil/#findComment-4732459
whats every ones thoughts on using penrite hpr 15 0nce i flush my oil? also iv been told if i use the shorter z170 filter instead of the longer z115 (both do fit the z115 is the standard recomendation for a c210 the z170 for the r30) it will boost my oil pressure slightly witch makes sence to me but is this a bad idea in an engine 28 yrs old with almost 170 000 km on the clock? any ideas would be greatly apreciated
https://www.sau.com.au/forums/topic/270784-oil/#findComment-4733715
where when n how much do i need to buy
i been told to use penrite hpr 15 but im gona flush it with crappy gtx first
http://www.skylinesaustralia.com/forums/Ma...Gr-t276540.html
just pm me if ur intersted
i use it in my 34 and i wont touch anything else at all anymore
https://www.sau.com.au/forums/topic/270784-oil/#findComment-4734386
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
