As per my tuner's recommendation, Castrol Edge 10W60, and that's with a turbocharger bolted on. I think as Dan said 10W40 will do the a good job on a N/A
redline 10w-40, $168 for 3.8ltr
i would not follow what the manual says as we are in Australia and not japan so the oil preforms differently. You will need a thicker oil than 5w-30 because you will get unwanted engine wear over time. Best weight is 10w-60
the only reason i have 10w-40 in my car is because its only one 453km ...... literally. don't go thinner than this.
ended up servicing the car with MOTUL 4100 turbolight 10w40
cost about 60 or 70 bucks for the 5 liters, car runs heaps better now definatley reccomend this oil for your n/a skyline
motul 300v chrono - 10W40
cost me $110 for 4L going to get another 2L tomorrow lol.
but even with 4L in it, it runs 3947464657048 times better, makes a huge difference.
next on the list is the gearbox fluid :) lol
redline Lightweight shockproof has probity saved my gearbox. I dont care is cost more than gold my gearbox stopped being clunky and made it feel new again :)
ended up making every single part in my car that needs oil being redline oil and dont forget the coolant :)
  • 1 month later...
81 skyline mgc 210 coupe l24e engine 168 000 km on the clock what oil would u reccomend iv been told if i use too thin an oil it may leak out the seals being an old engine but no one will give me a strait answer lol
The reason for not using a thin oil on an older engine is because of the engine bearings ...
if you use a thinner oil it increases the possibility of you spinning a bearing
just like in a used differential it is unwise to change diff oil with old bearings ... as when you add fresh oil with old bearings they fail
whats every ones thoughts on using penrite hpr 15 0nce i flush my oil? also iv been told if i use the shorter z170 filter instead of the longer z115 (both do fit the z115 is the standard recomendation for a c210 the z170 for the r30) it will boost my oil pressure slightly witch makes sence to me but is this a bad idea in an engine 28 yrs old with almost 170 000 km on the clock? any ideas would be greatly apreciated
I'm using Castrol GTX 3 15w40 - nothing special and meets specification the stock rb25de actually only requires GTX 2 equivelent, but since I change it so frequently it seems to suffice.
 Share
    • Update - new drop of oil noticed. Leak seems to be continuing, but a slow/small one.
    • Hey y'all! So I am the owner of a shiny new '99 ENR34 25GT-Four, 5spd manual. Took it to the tire shop to get new shoes. They mismatched the front and rear axles (225/40s on rear, 225/45s on front), so AWD system went bonkers for the next day. Took it back in, they fixed it, but I noticed about 8-9 big drops of red fluid in my parking spot. Leaking has stopped, but it's clear that the transfer case may have been stressed/hurt by this debacle. I'm taking it in for inspection tomorrow. If things are FUBAR, I have a few questions. - ENR34 manual transmission transfer cases seem impossible to source. Can a GTR transfer case fit? Or if not the whole thing, just seals or components? GTR is 6spd, mine's 5spd, so I'm thinking no, but lmk. - Finding a few RB25DE NEO AWD auto transmissions for sale, for decently cheap. If my only option is to swap to auto, what else will I need besides an auto-specific gauge cluster, and associated wiring? - I imagine the R32/33 GTS4 transmissions/transfer cases are a no-go? They're not NEO engines, so unsure. - RB25DET/4WD setup from the Stagea, any parts that transfer over? I did search up for this on SAU and google, very little info covered.   This is my first post, so apologies for breaking any rules, please let me know, and thanks for the help.
    • Thanks. I agree, looking at those plugs in conjunction with good compression/leak down tests I'm not too certain its ring related anymore.  I have a Swagelok ball valve on the drain and tubed it lower down to the left side of car to easily dump it into a container. I do not drain back into the sump. I've never had to drain it though as there's never been any oil in it.
    • Best bang for buck at the moment would be a 86/brz. Good chassis,  plenty of aftermarket support and parts everywhere.   I just picked one up with some quality gear and it drives better than my old 180sx.    Also depending on what your doing and budget.  An a90 supra is my pick if want to spend more. Great chassis, solid motor, gearbox is good. Development potential is crazy. They are doing well in prod sport and time attack. All the old jdm stuff needs alot of work as most of it all bent and over priced.
    • It's basically the same platform, hence why everything bolts to everything else Kelford camshafts were recommended by Mania after they asked me what I want the car for, I said "I'll thrash it around daily and maybe take it to the track for fun" 🤣 Factory NC 2.0L cam specs: - Adv. Dur. 256 /256 - Dur @ .050 205 /190 - Lift 9.42mm/8.13mm So, as I know nothing about cam specs, all I can say is the numbers are different and it should get a little bit of lope....🤣
