  • Replies 121
As in, on the street, you're not likely to see boost, unless you wind it up in 2 - 3 gears first.
however you are most likely to find small birds in your engine bay..
we really need pics of you naked to help...
:P
have you ever driven a turbo car? since your NA and all...
and i believe a fence post jumped out in front of you before, well even with a standard turbo that fence post will be lodged in your front bar allot quicker.
sorry to be harsh, but you have to think logically, best option as someone else said neo turbo motor dropped in and leave it and learn to drive it.
Edited by 32_Dave
Frank answer... yes that turbo will do the job, you already know that tho, you can look up the rating on a turbo anywhere,
Is your engine at that turbo a good package to use to do the job? No, its dumb, nothing personal, no "your a girl and dont know better" just from one skyline owner to another.
Using an NA package and converting it to turbo and then going for big power is really just an exercise in spending. anythings possible if you spend enough on it.
BUT, it wont be reliable.
Better compromise, get a 25det neo engine and drop that in, use that as a base, you'll still have issues and spend lots, but you might spend a little less in the long run.
If, like climbing a mountain, your doing it "cos i can" then dont ask... just do it... spend the cash, the time and live with the results. you'll get your power for some period of time.... then you'll do something else.
Now think, other that "Huzzah!!! i gots powah!!!" what are you really hoping to acheive?
I agree with what everyone is saying, I think you should look at dropping in a neo turbo engine to begin with. I think the power level your chasing from the get go is unreasonable, not because its unacheivable but because there are so many things to factor into the build rather than "Im building a show car and I want this much power" There are plenty of insane cars out there running less power than this, plenty of show cars out there running less power than this and it seems that all your chasing is the "aw factor".
Also try to do some research on cars that use the t51r, I believe the godzilla motorsports 32 GTR runs the t51r SPL, research some 34 GTT's that are making good power. You will get more satisfaction from a gt2835 or hi flow on the street than you will t51r.
If I was in your position, building a fast streeter id be going hi mount 35 series turbo, but thats just me.
She's not building a streeter, she's building a show pony. Nothing more, nothing less.
Oh, and MISSR34 did you ever find your missing KWs that your knock sensors were supposedly hiding... With your PFC and all that doesn't do anythign with the knock reading other then flash a light...
See, we'll let that be lesson one for all the boys here.
She WON'T listen to you, no matter what you tell her. Supposedly knock sensors caused her to be majorly down on power, whilst she ran a PFC... Oh, and she argued black and blue they were the fault... :ninja:
Since your engine builder has suggested that turbo - use it. If you dont have faith in your engine builder - go somewhere else and use whatever turbo they suggest. If you dont follow your engine builders advice they have an out if there's a problem, and there's more likely to be a problem as other stuff like headwork, cams etc will be selected to work well together. Throwing a random, potentially missmatched piece of kit into the mix is not a good approach.
knock sensors deff can make you down on power, if the tuner is using them, and backs the tune off early...
dont bother with a neo motror, you'll need a full rebuild for 500rwkw either way, so why spend the extra coin on bits you'll be replacing anyway
did you make a thread like 2-3 weeks ago about making your N/A supercharged?
Oh yeah, i remember her, i read that whole thread then it disappeared and I wondered what happened,,,all i can say is the determination she is showing far outweighs her rational thinking. Sure, if you got the money to spend and have absolutely NOTHING better to spend your money on,, then go ahead, good luck and godspeed
You should really add what you want to know about the T51R. From your post you aren't worried about spool etc, so thats good as there won't be much - and you want >500kw which is what a T51R will do fine as well.
What is it you DO need to know about it? It might help you get some more constructive responses - especially if you give some input on what your intended engine build spec is, you are still using the 25 block? Fully forged etc? What fuel will you be dyno queening on?
ill be going RB25 top end with RB30 bottom end to help with torque.
yes it will be fully forged and ill be having custom cams made up aswell (the cost the same as buying ones of the shelf).
ill most likely to be using Martini Racing Fuel for dyno comps
if ive found the right information, the Garrett GT4594R is basically the same as the HKS T51R, so ill be going with the Garrett one. I just thought maybe some people on here have used that turbo, or know some more information about it? just in a general sense really.
i have my list of everything that i need to get (im always adding to it as i go tho). But cause i pretty much know SFA about turbos, and im willing to admit it, id just like a little help, but like you said i prob should have made it a bit clearer to begin with.
do you have a boyfriend?
what does he say about your endevours for a 500kw car??
cos i'd be seriously pissed if my girlfriend wanted to waste that much money on a car for a few minutes of fun on a dyno at a car show, cos honestly, it seems that a car with over 300rwkw on the road is pretty useless and to only really use the power on a dyno or on a track really wouldnt be worth the money.
try fooling around in bed, much more fun than sitting in a car on a dyno pulling over 500kw
just my two cents
unlike yourself, id get more satisfaction sitting in a 500rwkw Skyline than what a guy could ever do for me :D and no, im not a lesbian.
and no, i dont have a boyfriend. and if i did, its love me, love my car or get F***d.!
agreed - a proper plan which is based around the 500kw u want is a good idea,
as apposed to just chucking expensive parts together willie-nillie which has the potential to leave you out of pocket, and unsatisfied..
you need to get laid.
:D
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
