WHEELS:
* 20x8
* 5x114.3
* OFFSET +35
TYRES:
NANKANG 245/35's
The offset is good for a ARX but not sure how that will sit in a RS/RX.
I have seen a car with 20 inch rims and that was lowered so should all fit.
Cheers
Andy
WHEELS:
* 20x8
* 5x114.3
* OFFSET +35
TYRES:
NANKANG 245/35's
Yes.
You will fill out the guards nicely (width wise) and your speedo will only display 1.7% slower than your actual speed.
Assuming your current wheel is the stock wheel is the 17x7 +45, 215/55's that came on RS/RX's
Try these to make sure
Wheel Offset Calculator
Tyre Size Calculator
Sorry to hijack your thread Houdini :P
I just went and checked out Osaka rims, how would I go with a 19" x 8, +38 (or +40) offset on my slightly lowered RS?
I decided to drop down to 19" to avoid any guard rubbing or tyre shredding, would be running 245x35's.
You should have no problems, going to +40 18 x8 from +45 17 x 7 pushes the wheel out about 17mm.
When I measured I had around 28mm to inner guard lip on the rear and about 25mm on the front. This is at stock height, lower will introduce some camber, so you'll have slightly more clearance.
If you're unsure use a straight edge (I used a 600mm steel rule) across the face of the rim, then up under the guard.
These are the rims I was looking at today
http://www.lwtwheels.com/wheelzoom/mannuszoom.htm
I also liked these one's but there was a concern about them clearing the brakes once they are upgraded to 350z brembo's etc.
http://www.lwtwheels.com/wheelzoom/sparkszoom.htm
I'm hoping the black & silver will set off well with the tinted windows and the wine red colour, plus I wanted to keep with the whole japanese theme hence why I was eyeing off the Osaka wheels. :D
Don't mind the first one, the second is a bit fussy, too many surface changes, look like they should be on a yellow hummer. I reckon six spokes looks a bit funny too (Just my opinion tho').
Black will be a nice contrast against the red, a little machined alloy will pick out the chrome on the door handles. I'm a sucker for a black wheel. :D
Something a little understated, with the right offset looks tough.
Thanks man :) i think the first one is growing on me now, it was my second choice but I really want to upgrade the brakes after the turbo is hi-flowed etc. so the first one is the most practical.
I've also have chrome or silver so yeah, black will be something different for me ;)
I agree the second one's look like they belong on a hummer, not that there's anything wrong with that :nyaanyaa:
I like both of them and in fact the first one is something that caught my eye. I started the thread because I found some second hand one's for cheap-ish. I'm keen to get a set of mags and drop the car down a bit and I'll be happy for a while as I think that sort of look is nice and tough and sporty and matches the performance of the car a bit.
I too want the brembo's. Hey ask 'em how much for two sets of the first wheels and see if we can get a discount! I'll come up for lunch, we get our wheels fitted and bob's your uncle.
I'm looking at a set of wheels on here too but no tyres and I'm unsure how much it'll set me back once I've got rubber on them. It'll be a temp set on the ways to the ultimate wheels. Hmmmm. Decisons decisions.
No pic on the wheels site of them on a car so I found this one.
Hey on that, would a set off this dunnydoor fit our Stageas? What I mean is if we found some 2nd hand (this set was for sale but sold already) could we get them for our cars?
Bis pm me with price on these (i know what the 2nd hand one's went for)
Edited by Houdini
Nah man, Commodore pcd is 5x120mm, Stagea is 114.3x5 :sick: offset is ok +42 versus +45 (rs/ rx).
The wheels might even go on, but you'll end up breaking wheel studs - not good.
Late model Falcon is correct pcd, and offset is +40, so all good,as long as you don't go too wide.
Late model falcon, cool thanks.
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
    • 😂 thanks guys. The diagram i had did not have the breather on it at all. Much appreciated.
    • Geez, engineers fees have definitely gone up. Mine back 2007 cost me all of $300. Mind you, I had to go back to him a few times to get him to write the correct things on the report after he'd inspected it. Things like wrong exhaust size, wrong wheel sizes, etc etc.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
