anyone who can help me would be great.
just wanted to know how much power can u lose on a dyno reading due to having big rims on the car. i was told u can lose 15 to 20kw!...... is this right or shouldn't it make that much of a differance.
thanks..
thanks..
I recently took off my 17" Volk AV3's and temporarily fitted 18" Speedy Cheetahs and noticed a slight power decrease. I'm guessing that's due to the Japanese rims being lighter in weight. Wasn't very much but certainly noticable, so should be the same during a dyno run? I'm replacing those Cheetahs with Gram Lights next month anyway so hopefully I can reclaim that lost (1.5kw? >_< ) power.
the wheels will add load to your hubs, which might make it marginally lower, but the kW difference should be negligible... however the added weight of the rims and the lower profile tyres will affect your handling much more noticeably.
Also maybe people who run bigger wheels opt for cheaper/less grippier tyres, and therefore on a dyno there's more slip?
So what ur saying is differance wise on the dyno it should be a little differant. It won't be a massive difference like 20 kw! LOL if u got 20"a on the car compared to the stockys 16"s can u lose 15 or even 20 kw atw if say i pull the 170 kw mark on the dyno.
so will i be ghey if i roll up in a stock r35 with stock 20s?
LOL!
an r35 gtr comes with 20" wheels stock so it wouldn't be ghey at all. however a 33 or 32 gtst with aftermarket chinese 20"s = ghey + chinese made - coolness = fail at life so jump off a bridge.
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
