New Car
Jor33dan
 Share
just bought a 1994 r33 4 door gtst turbo
wat do i have too do too get the engine bay looking like show condition?is there certain things i can take out that arent necesary
and how much would it cost???
cheers
to do it properly,
take the engine out and repaint the bay
polish all the bits etc
if you dont have to time or the knowledge to do that
go nuts with a rag and some degreaser
how long does it take too take out the engine??
Bleeding is generally a term for when you pierce your/other people/animas etc flesh and you get blood coming out.
^^what he said :closedeyes:
well if used correctly it is lol, ie:bleed the brakes/clutch :laugh: but yeahh, im a 3rd year nissan apprentice and i can tell you right now i guarentee that if your gunna work on a car you'l always find something to cut yourself on no matter what your doing :closedeyes:
not too good aye..what parts can i pull out that arent necesary?
-fuse box, you can relocated it so its not in the engine bay
-Washer Bottle
-Carbon Castor
There is alot of stuff you can remove or relocate but its up to you how far you go and how much money you want to spend
well if used correctly it is lol, ie:bleed the brakes/clutch :) but yeahh, im a 3rd year nissan apprentice and i can tell you right now i guarentee that if your gunna work on a car you'l always find something to cut yourself on no matter what your doing :ninja:
hahaha ok cool.i knew it was a car term.ahh thats alright bit of blood is nothing too worry bout
-Washer Bottle
-Carbon Castor
would a mechanic charge much to rmove items/relocate?
take a photo of your engine bay and we can see whats stock and whats not.
Then we can give you a list of simple things to take out and polish up.
ps do you want me to fix your username up to show a user name and not ur email?
ok will do.
im not sure how 2 aye.ye if ya can that woud be cool :ninja:
Edited by [email protected]
dude get your hands dirty, dont pay someone to do it, start off small and work your way up, anything you are not sure about. research and more research, we all had to start from square 1.
 Share
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
    • DCS, war thunder, IL2 - mostly flight sim games.
