can someone explain to me whats the difference between th RB26DETT on the gtr 33 and the 34???? do the produce the same power and performance?
basically i want to convert my r34 GTT to a RWD r34 gtr and i read in more than one place that it is possible, and i found a pretty cheap r33 gtr engine and want to know if its different than r34's engines..... i'm not an expert in skylines so if someone thinks that i'm thinking about to do something not possible please advice me
R33 and R34 GTR engines are the same.
Both RB26DETT, but there would have been a few refinements for the R34. (Tuning wise)
Both R33 and R34 GTR's came with the standard RB26 and the N1 Editions came with N1 engines.
...and thus, the refinements lead to more torque from lower down in the rev range.
thanks guys for the replies....so what you are saying is that if i put the rb26 from the r33 gtr on my GTT and tune it properly it should perform exactly just as an rb26 from r34?
did i get that right?
nearly = not quite = just about = virtually = so close = Hmmmmm = or as Maxwell Smart says, "missed by that much"!
AND ONLY IN A STRAIGHT LINE WITH THAT GT-T RUNNING GEAR (since you asked about performance too).
At the end of the day H B, if you're getting a great deal with an R33 RB26DETT motor, I wouldn't be put off from going ahead with the conversion.
And if you really want to boost your torque (since your engine is out already), budget for a couple of TE25/30s or HKS RS turbos too.
All the best with it! But don't forget your stoppers!
Agreed. It was the package as a whole that was more upgraded than the engine and gearbox. While there are tuning differences, and with that, power differences between the r32, r33, and r34 model engines, they are essentially the same engine.
That's why I should sell my 33 gtst and buy a 32 gtr now instead of pissing away any more money, and starting with the better package. But I'm an idiot.
Realistically, age and km's are more important than the series of gtr the engine came from. Unless it's a Nur. Or has been rebuilt. Or particularly strong or weak due to factory tolerances. Or if you buy the engine on a Tuesday. you get the drift......
there are differences between motors........
the most obvious difference is the Rocker Cover on the Engine... R34 being Red paint & R33 just plain black base colour.
they peform slightly different power in tuning.
The R33 RB26 is closer to the R34's than it was with the early R32 Rb26's, as the Crankshaft had a slight difference in size as well as it causing problems with the oil pump.
The head on the R34 has been improved after the R33....
The R34 Rb26dett has a Aluminium Inlet Plenum Chamber, where the R33 has a plastic one.
The crank angle sensor on the R34 is black, where the R33 is metalic.
there probably are more little differences here and there
huh? The inlet plenums are exactly the same! The real differences between the R32/33 and R34 RB26s is as you mentioned the R34 runs a different CAS which means you need R34 specific cams Main difference is the R34 runs far better ceramic ball bearing turbos, giving the engine better torque characteristics and ultimately a few more kws when tuned up with an ecu and exhaust.
well ive never had a r33..
the colour is different
in that case the colour is different
with the R34 being aluminium and the R33 black
2x R33 engine bays
R34
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
