Hey guys, bout time I got rid of some stuff thats taking up place in my garage...
HKS Mushroom Pod Filter - You all know what these are so don't need to explain much - $50 ono
2 x Single 2.5" into twin 3.5" upswept exhaust tips - few minor scratches all on the under side, had these on for four weeks then had to change due to body kit. They look very tough - $30 Each or the pair for $50
Polished stainless muffler Single 2.5" IN twin 2.5" OUT - came of a mates car has a very nice note to it - $50
R33 skyline DeCat pipe with Sensor fitting - Had this made up for my skyline no longer required, it was made for an R33 but might suit other cars not sure - $50 ono
Trust Muffler off my R33 3" in with 4.5" Tip - This is a genuine Trust muffler and has an awsome note to it plus has the larger body (not a cannon) which makes the car fairly quite at low revs but when you get into it sounds awsome - $95 ono
Genie Cannon 3" in with 5" tip - This cannon is massive and sounds insane plus looks awsome had it on my R33 and definetly stood out - $95 ono
Pair of R33 tail lights - Good condition don't really need to explain much - $40 each or $70 for the pair
Set of Series 1 R33 RB25DET Coil packs - Working fine when removed from car, removed due to rebuilding whole motor and putting external coils in. - $30 each or $150 for the whole set
RB25DET Tommy Kaira Engine Cover - came from my motor but due to going external coils could no longer use looks awsome and really sets of the engine bay. It's fully cast - $200 ono
R33 Series 1 Nismo Wing - painted marron and no damage, It the one thats a bit higher than the standard one and sticks out over the back of the car - $100
Sony Rear Projection TV 68cm not widescreen - $50
Benq 17" LCD monitor - $50
Geforce Graphics car for computers - Great upgrade to a standard system - $30
I'll get more pics if anyone wants something in particular
Contact me via PM, need to get some funds for this weekend so if theres somethin you want give me an offer and i'll consider it
https://www.sau.com.au/forums/topic/270840-garage-cleanour/
hey mate
have u got pics of these items??
thanks
https://www.sau.com.au/forums/topic/270840-garage-cleanour/#findComment-4611362
  • 4 weeks later...
Sorry for the delay with pics,
As you can see, I also have a stock BOV, both wing mirrors and A cold air box for an N/A R33...
Make an offer on these items.....
Edited by redevil
https://www.sau.com.au/forums/topic/270840-garage-cleanour/#findComment-4691069
    • How would i degree my cams on an rb25 hydraulic lifter head? lots of information online about degreeing cams on NEO or rb26 heads with solid lifters but cant find a definitive answer about hydraulic lifters. is the process just the same for both hydraulic and solid lifters on an rb (dial indicator on top of the lifter for measuring valve position) or do i have to mess with my lifter to make it solid for the degreeing process?
    • Hmm. Two terminals. Probably just conductivity. If you knew the shape of the curve, you could probably just do it with a multimeter.
    • Clinton and I spoke to Alan Heaphy at length last year at the Bathurst 1000 about the Gibson GTR's that he had at the track and the restoration work that his company was involved with. He has a number of people working for him who were part of Gibson Motorsport when these cars were being built and raced. What impressed me the most was the amount of first hand knowledge and information that he and his team have about the Gibson GTR's and their meticulous attention to detail in the restoration and maintenance of these cars.
    • When you track RPM vs time it's clean, unlike the OEM one, even with filtering there are ripples. Means no random misfires or triggering issues at higher RPM, especially if you have big lift cams and a noisier valve train due to heavier springs.
    • Brake Fluid testers are cheap and readily available....eg https://www.supercheapauto.com.au/p/endeavour-brake-fluid-tester-rechargeable/SPO9539349.html
