  • Replies 55
Posted Images
I've been keeping track of my fuel consumption on my iPhone...
Because of work I'm also making lots of short trips of about 10 min / 2 to 9Km every hour or so... ...I think I got around 600Km on a GOR cruise once and around the same going up to Swan Hill... ...But that was before I started recording my fuel...
i used to get approx 450km (30km of that after fuel light on) max. fairly stock auto. haven't had a chance to check economy recently as i've had it tuned, and still in the "honeymoon" phase :D
I don't think I've ever seen the fuel light... ...How low does the needle get before it comes on???...
For my car, it came on when the needle is like about 1/2cm or so under the E line.
& I only know this because when I picked up my car from the panel shop, they pretty much drained all the fuel out & I was driving on empty :( .
Thanx JamesK,
i got an autoban just down the road from me, ill pop in there on the weekend and see wat they can do for me about an o2 sensor,
hopfully that might get some more ks, if not, it cant hurt getting a new one :)
Forget autobarn, save some $$$ and time and order from HERE $77 and quick delivery.
I've never been brave enough to let it get that low... :(
Dont you mean stupid enough, efi fuel pumps dont like running dry.
Replaced the oxygen sensor tonight. Got her up on the hoist and laughed at why I even bothered putting it up there when the sensor was clearly visible from the engine bay. Then I ate my words when a seemingly 2 minute job turned into 2 hours. The positioning of the sensor is so damn awkward. Near impossible to get a grip on the sensor nut with a torque-worthy tool. My open ended spanner kept slipping...shifter couldn't get a grip...socket wouldn't fit over sensor. Didn't want to thread the sensor nut so I resorted to snipping the sensor wires in order to get an angled ring spanner over the nut (forcing me to get the new sensor installed or being unable to drive home). Still had no room to get any decent leverage though. Had to remove the heat shields from turbo and exhaust - the screws of which were rusted through and threaded themselves when I tried to remove them. Drilled some of them out and vowed not to put the shields back on afterwards. I was quite literally bracing myself against the car chassis while trying to unhinge that rusted piece of crap sensor. After every swear word in 4 or 5 languages she finally cracked. Putting in the new one took the other half of the 2 minutes I had originally intended to spend on this.
/end rant.
Here's hoping my fuel economy improves because my anger management sure isn't.
Oops should of posted up earlier I have an O2 Sensor socket if anyone nearby wants to borrow it...it does make your job a crap load easier as birds may have found out that damn thing is in tight!
My sky is on average on about 11.4L which i was happy with UNTILL my car broke down and started driving my brothers spare care, 1.8L Corolla. Geezzz, fill 40 L, done 550kms and i still got one line to empty. I cant belive the difference. You save about 7 dollars per 100kms. woow
In saying that, the car has no balls nor handling nor looks nor anything else. lol just a lil engine.
ive never seen a fuel light come on ever..
didnt know there was one
There is guys, trust me I was in the same boat as you guys but it only comes on when your needle is ON E like basically the light is REFUEL NOW!...haha but in the manual it says there is 7 or so lts left in the tank and even when your start to get at that level it will still start to fade on and off until I think about 5lt
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
