Tuned by DYNO TUNZ (Browns Plains, Bris, QLD) safe run-in tune (mid-range power) purely to allow the new mods to run in. Recently got a compression test done and the results were 175 for all 6 cylinders. The car gets an oil change every 5000km using Royal Purple oil. Most of the modded parts were brand new when they were all fitted at the end of last year and have only done approx 1500kms..
Personal plates 71LLA comes with the car!!!
Year: Late 1997 (Series3 - Rare as there are not many later model R33s, mostly 1995)
Colour: Black
-Engine-
- NEW Garrett 2 x 2860R-5 (HKS 2530 Equivalents)
- NEW HKS Adjustable Actuators
- NEW Genuine Nissan exhaust manifold & Turbo studs & nuts
- NEW Genuine Nissan Manifold/exhaust/dump pipe gaskets
- NEW Tomei Stinless Dump Pipes
- HKS twin 2.5inch exhaust/muffler (single pipes from each turbo, not your usual Y join type.)
- NEW Tomei Poncams (260degree, 9.15 lift)
- NEW Top Secret Adjustable CamGears (gold)
- NEW Gates timing belt & tension bearings
- Apexi Dual air filters (virtually new)
- Nismo Intercooler
- Trust/Grex Oil Cooler and Relocator with thermostat
-Elecronics-
- NEW Power FC D-Jetro with Hand controller (MAP sensors not AFM)
- NEW HKS EVC (V6) boost controller
- NEW Apexi Pen Turbo timer
-Fuelling-
- NEW SARD 650cc Injectors
- NEW SARD Fuel Pressure Regulator + pressure gauge
- NEW NGK IRITOP7 Spark Plugs
- NEW Walbro 341 (255L/hr) fuel pump
-Handling-
- NEW RDA slotted rotors (front)
- NEW EBC Red Stuff brake pads
- V-spec suspension with King springs
- 18inch R34 GTR Forged Alloy wheels
- BF Goodrich 265/35/18 Tyres
-Driveline-
- GTR series 3 gearbox
- NEW Exedy/Nismo cushioned brass button clutch
-Exterior-
- Xenon HID lights (only came on series 3)
- NEW ARC Titanium radiator air guide
- Nismo 400R front bar (2 Piece)
- NEW Nismo smoke side indicator
- NEW Nismo carbon fibre bonnet lip
- NEW Nismo clear front bumper indicators
- Interior-
- Dual Airbags (front passenger & driver)
- Nismo 300km/hr carbon 4 Wheels
Low Boost: Max Power 261.4Kw 14.9PSI
High Boost: Max Power 292.1Kw 20PSI
The price I'm after is $30,000 ono. Serious buyers only, no joyrides, no test drives & stupid offers will be rejected. I will take pics of the car & post them by the weekend.
The person who purchases this car at my asking price will also get a set of freshly painted (black) Genuine Granador Super Mirrors with blue tinted glass that I never got around to installing.
Edited by Blitz_R33
PMs replied. Price lowered to $29,000.
Here are some quick pictures I took on the weekend. Sorry I have not been able to supply more pictures, because I've been doing lots of overtime or work. When things die down, I'll take more pics and post them..
Edited by Blitz_R33
I'll try n get more pics but its been hard since i've been working long hours at work, so by the time i get home from work its to dark to take any pictures. Lately the days that I'm home during the day its raining, so I can't win.
Either way, the pitures I have posted so far shows you what my car looks like. If someone is interested they are better off coming and seeing it in the flesh.
  • 3 weeks later...
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
