My right hand rear taillight (the largest one) is not working properly on my R34. It will light up when I put the head lights on however when I depress the brake pedal it does not get brighter.
Because it seemed that the globe was working (as it lights up with head lights) I tried changing the fuse however this did not correct the problem (the one in the engine bay marked "Tail Lights" however upon thinking about it, had the fuse been faulty all of them probably wouln't be operational). So do you think there is a problem with the globe? And if so how do I get to the f*cker? (I opened up the carpet in the boot but I think I may have to take the whole light out somehow?)
Thanks for the help on my n00bish question!
https://www.sau.com.au/forums/topic/270931-tail-light-problem-r34/
It will be a twin-filament bulb - 1 filament for the tail light and 1 filament for the brake light.
The brake light filament has pooped itself. Get a new bulb.
NFI how to get at the bulb, but it probably won't be all that difficult if you look carefully.
yep..globe sounds like its gone..
and correct the whole tail light comes out.. there are a few nuts that have to be taken off... 10mm DEEP socket will do the job perfect..
From my experience - open the boot and remove the lining (secured via some plastic quarter turn screws) - you should then be able to remove the bulb from behind.
I have an r34 4 door btw... not sure if it differs from a coupe....
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
