hey guys i bought a oil cooler and relocation kit and i was wondering what the best way to install it.
can i mount the relocation so the oil filter points up? if so should i crank the car over a few times when i do oil changes to get pressure?
or should i just mount the filter down?
also should i have it so the the comes from the block to cooler to filter back to the block? or other way around?
cheers
Put the oil filter relocator wherever it's most convenient, mounting it pointing up can be alittle messy when the filter comes off. If you are worried about pressure try a smaller oil filter like the Z445 (edit: seems the thread is different than the Z145a) I think it is, instead of the Z145a
Edited by Moodles2
ok arent you suposed to fill the filter and lines up with oil every oil change? would be hard if you mounted to filter point up, id rather it pointing up but if i had to fill the filter up everytime then id mount it pointing down?
yeah you do not need to drain the oil cooler every change. it's too hard unless your cooler has drain plugs fitted. if you do dran it simply remove cas or similar so you can crank the engine without it fiting. then lit it crank until you get oil pressure on the gauge. then your good to go. the twin oil coolers in my RX7 do have drain plugs on them though which is nice, but i've never seen an aftermarket kit that does. and the small amount of old oil in the lines and cooler is not a big problem. especially if you use good oil.
I never drained the cooler or lines either, ran one on my SR for 3years with no probs. If your not running a thermostat just remmeber in winter its gonna take a while for the oil to get to operating temp.
  • 5 months later...
if you loose a motor I personally would replace the oil cooler. you can have them backflushed but if it spun a bearing and bits of bearing material made it through the pump then chances are there is some in your cooler. It can be painful if it's an expensive one but is it worth risking the new motor? it does depend on exactly what happened though.
always always always replace the oil cooler, and also the cooler on the factory water to oil cooler next to the oil filter. $300 but you just cannot flush them out properly. As always I speak from experience in these matters :P
Duncan & BBaron if I ever doubt ya point me back to this thread
pulled the factory oil cooler thingo apart an well pictures say a thousand words they reckon
see now how impossible it would be to clean as well
oh well back to Nissan to hand over more hard earned
reckon I will pull all the sensors an stuff off an hot tank the base too
whats another coupla gaskets etc
always always always replace the oil cooler, and also the cooler on the factory water to oil cooler next to the oil filter. $300 but you just cannot flush them out properly. As always I speak from experience in these matters :blush:
You must go through a lot of oil coolers... :)
Priced factory cooler today now $420.10 according to my local Nissan
got a look at an rb20 today reckon the filter block looks like it would bolt up
unfortunately the owner of said rb20 wouldnt let me unbolt it to try it out?????
Just wondering if there is a recommend reliable oil cooler setup that is tried and tested for a 26, even it costs a little more? Given our dollar, a Japanese or even American unit would be reasonable I imagine?
The trust setup comes with a BNR32 arrangement: http://www.nengun.com/trust-greddy/oil-coo...andard-location
Or perhaps the PWR core with some custom lines: http://www.horsepowerinabox.com/HPIAB2/category82_1.htm
it is fairly straightforward to get rid of the factory cooler and bolt a oil filter relocator directly to the block. a lot cheaper when nissan want that sort of money for the factory bit.
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
