hey guys i bought a oil cooler and relocation kit and i was wondering what the best way to install it.
can i mount the relocation so the oil filter points up? if so should i crank the car over a few times when i do oil changes to get pressure?
or should i just mount the filter down?
also should i have it so the the comes from the block to cooler to filter back to the block? or other way around?
cheers
Put the oil filter relocator wherever it's most convenient, mounting it pointing up can be alittle messy when the filter comes off. If you are worried about pressure try a smaller oil filter like the Z445 (edit: seems the thread is different than the Z145a) I think it is, instead of the Z145a
Edited by Moodles2
ok arent you suposed to fill the filter and lines up with oil every oil change? would be hard if you mounted to filter point up, id rather it pointing up but if i had to fill the filter up everytime then id mount it pointing down?
yeah you do not need to drain the oil cooler every change. it's too hard unless your cooler has drain plugs fitted. if you do dran it simply remove cas or similar so you can crank the engine without it fiting. then lit it crank until you get oil pressure on the gauge. then your good to go. the twin oil coolers in my RX7 do have drain plugs on them though which is nice, but i've never seen an aftermarket kit that does. and the small amount of old oil in the lines and cooler is not a big problem. especially if you use good oil.
I never drained the cooler or lines either, ran one on my SR for 3years with no probs. If your not running a thermostat just remmeber in winter its gonna take a while for the oil to get to operating temp.
  • 5 months later...
if you loose a motor I personally would replace the oil cooler. you can have them backflushed but if it spun a bearing and bits of bearing material made it through the pump then chances are there is some in your cooler. It can be painful if it's an expensive one but is it worth risking the new motor? it does depend on exactly what happened though.
always always always replace the oil cooler, and also the cooler on the factory water to oil cooler next to the oil filter. $300 but you just cannot flush them out properly. As always I speak from experience in these matters :P
Duncan & BBaron if I ever doubt ya point me back to this thread
pulled the factory oil cooler thingo apart an well pictures say a thousand words they reckon
see now how impossible it would be to clean as well
oh well back to Nissan to hand over more hard earned
reckon I will pull all the sensors an stuff off an hot tank the base too
whats another coupla gaskets etc
always always always replace the oil cooler, and also the cooler on the factory water to oil cooler next to the oil filter. $300 but you just cannot flush them out properly. As always I speak from experience in these matters :blush:
You must go through a lot of oil coolers... :)
Priced factory cooler today now $420.10 according to my local Nissan
got a look at an rb20 today reckon the filter block looks like it would bolt up
unfortunately the owner of said rb20 wouldnt let me unbolt it to try it out?????
Just wondering if there is a recommend reliable oil cooler setup that is tried and tested for a 26, even it costs a little more? Given our dollar, a Japanese or even American unit would be reasonable I imagine?
The trust setup comes with a BNR32 arrangement: http://www.nengun.com/trust-greddy/oil-coo...andard-location
Or perhaps the PWR core with some custom lines: http://www.horsepowerinabox.com/HPIAB2/category82_1.htm
it is fairly straightforward to get rid of the factory cooler and bolt a oil filter relocator directly to the block. a lot cheaper when nissan want that sort of money for the factory bit.
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
