Hi guys have a problem with my diff there is a clunking coming from the left rear the sound is only there under acceleration and sends vibration throughout the whole car.
I took the car to my mechanic who welded the diff because the spider gears were shot and replaced the cv's didn't really help at all though he doesn't seem to know, he was telling me it was the front of the diff but i have my doubts because the noise is definatly on the left.
The noise only started after i lowered the car at the rear could it be the shafts angle has changed so the shaft that is on the right is of a shorter length.
Think i should change the wheel bearings too can somone steer me in the right direction to get some replacements for these.
any suggestions would highly appeciated
Brendan
https://www.sau.com.au/forums/topic/270969-dr30-diff-woes/
If it's the same as the DR/HR/MR30 the hub has to be dismantled and it's a whole lot easier on a bench than in the car, so the trailing arm would have to be removed. An Harmonic Balancer pulley works well getting the hub apart. The bearing cones can be drifted out and tapped/drifted back in, but just be sure not to set them in off centre (crooked) as you might bend the cone or break it.
Once you have the bearings out, take them to any bearing sales outlet and they will match the numbers. Ask nicely and you'll get 50+% discount off retail and you will save a bomb against genuine Nissan for same thing.
A steel drift works getting them out, but a brass one is best putting them in, less chance of damaging the cone with a brass drift. Failing this, get a shop to press them in & out. Then pack the bearings with high temp wheel bearing grease of about 220 viscosity or better and install in correct cones and re assemble hub.
My personal favourite is Mobiltemp 220 100% synthetic grease, but it's hard to get and only available in 2.2kg cans.
Cheers, D
https://www.sau.com.au/forums/topic/270969-dr30-diff-woes/#findComment-4606895
COULD be the front bearing, but another way to test if it is the rearaxle bearing is once at a cruising speed, hold your speed and move the weight of the car left and right.( swerve side to side, but not stupidly) the sound should come and go
cheers
Jason
https://www.sau.com.au/forums/topic/270969-dr30-diff-woes/#findComment-4606934
so they use a tapered bearing,
No I farked that up, sorry!
There is 2 bearings, an inner and an outer, normal roller bearings, but they are sealed. I removed the inner seals & washed the grease out, to re pack with synthetic, but the bearings still have to be drifted on to the axle. That's if in fact it's the hub bearings stuffed.
It's a few years since I did my rears on the PNV.
Do Drew's test first to confirm
Cheers, D
https://www.sau.com.au/forums/topic/270969-dr30-diff-woes/#findComment-4609006
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
