the clutch in the s1 260rs is in the very early stages of slipping/not going into gear about once every 2 or 3 days... u need to relese the clutch in neutrel and that sort of slips it back into a position it likes :S
whats am i looking for? push or pull?
how much is it generaly
how hard is it to change
and how heavy do i want to go :D
https://www.sau.com.au/forums/topic/270989-260rs-clutch/
I would imagine it would be the same as a R33 GTR clutch. If you do a search on this forum you will find quite a few reviews of the various clutches available. My 260 will need a new clutch, too. :nyaanyaa: Doesn't like launching at anything over ~4000rpm :laugh:
https://www.sau.com.au/forums/topic/270989-260rs-clutch/#findComment-4607467
i replaced my 260 clutch with an Exedy twin plate clutch - NM042SD
$2200 for clutch, ~$600 for labour.
best thing i ever did, changes the whole way the car handles
https://www.sau.com.au/forums/topic/270989-260rs-clutch/#findComment-4607587
Yep same as R33 GTR.
I got a cerametalic one from slide on here rated to 330rwkw, good price to.
Is pretty heavy and very bitey but if u want a good clutch that isnt $2000 then u get that.
I wouldnt recomend doing it unless u have a hoist and a transmisson jack, there freaking heavy and awkward, not any more difficult then a normal clutch change though, You will need to bleed the attessa aferwards.
https://www.sau.com.au/forums/topic/270989-260rs-clutch/#findComment-4607593
if you want the nicest clutch to drive yet can handle over 600awhp no problems, go straight for a NPC twin plate clutch, best in the business!!!! ive tried exedy, extreme singles and they are weak as and wont cope with hard 4wd launches for long. Direct clutch twin was nice to engage, super strong, but heavy as hell to press so dont bother. Os Giken quad plate i had was nice and soft and handles the power but its really annoying to engage and bunny hopping from lights is not cool :D
seriously if you want to get a clutch and never have to upgrade and have it drive and feel like stock then a NPC twin plate is the go, they are $2000 and way better than the other options. I've done 8500rpm launches with mine and 560rwhp at drags heaps of times and never slipped once.
Edited by unique1
https://www.sau.com.au/forums/topic/270989-260rs-clutch/#findComment-4611378
Yeah I just had my car retuned after I installed new turbos, and hit 254awkw which I am happy with however any more power and the clutch slipped, + turbo seal is rooted (great have to take em out send them off) anyway long story short is when mine goes I will bet a Jim berry as Ive only head good things.
cheers
https://www.sau.com.au/forums/topic/270989-260rs-clutch/#findComment-4611818
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
