hey guys
had a leaking abs unit in my 32 and swapped it out for one from a gtr
lines all matched up nicely and everything but i'm not 100% convinced that its working
when i turn it on it sounds like its priming itself (never did this before)
and i think i am able to still lock the brakes up (hard to lock them with good pads and 18 inch chromies)
So, does anyone know if the are compatible or if i have to change anything to get it to work propperly?
(or have the propper bleed procedure for it?)
Thanks
Tom
https://www.sau.com.au/forums/topic/270992-r32-abs/
I had a similar failure. I believe the unit was replaced with a GT-R unit; no problems with the operation of ABS.
You are more likely to lock the wheels with good pads, and I would expect "chromies" would make no difference. Why do you want to lock the brakes anyway? I rarely activate the ABS on mine, even during spirited driving.
Just bleed them in the normal course of events; I usually leave the ABS unit until last.
https://www.sau.com.au/forums/topic/270992-r32-abs/#findComment-4613736
ok must be in my head then
also brakes only lock up when there is to much pressure in 1 point instead of a distributed load that causes the pad to grip (this is what i read)
good brakes should be able to pull up much harder without locking
just got a cm or two of slack b4 the pedal goes hard
but it is apparently normal with the abs
https://www.sau.com.au/forums/topic/270992-r32-abs/#findComment-4613935
no one can help?
quickly loosing interest in sau
not a great deal of knowledgeable ppl it would seem
Yup.
Don't get a reply to your thread after 3 days, so you insult the people you are asking help from.
Way to go, champion :(
https://www.sau.com.au/forums/topic/270992-r32-abs/#findComment-4614023
sorry
used to boost where you get a half inteligent reply after a day at least
not to be smart
but check all my topics
there are about 8 that have had no replies
i put up plenty of info and yet i get no replies
just saying its pretty annoying
https://www.sau.com.au/forums/topic/270992-r32-abs/#findComment-4614031
did you bleed the abs unit? the better the brakes the easier it is to lock the wheels.
All you need to do to test it is get the car to 80-100, and stamp on the brakes. You should feel the abs through the pedal, and you should be able to hear the unit pumping. if the abs isn't working you'll get none of that, and you'll pull up in a cloud of tyre smoke.
https://www.sau.com.au/forums/topic/270992-r32-abs/#findComment-4614157
yeah i know what abs feels like
and kinda re bled the abs unit but i didn't have any hose and was just doing it with a rag and only a couple of pumps cos it was making a mess
couldnt see any bubbles coming out tho but will attempt it again when i find some tubeing
does anyone have a definitive procedure to bleed the mofo?
car on? car off? battery disconnected? either one first?
would love to get rid of the squishyness
https://www.sau.com.au/forums/topic/270992-r32-abs/#findComment-4615505
i've alway blead it with the car off, get someone in the car, get them to push on the brakes, and you open the valve. when he gets to the firewall close the valve, then he lifts off the brake. Rince and repeat, till there is no air.
order to do it is LR, RR, LF, RF, ABS R, ABS F. If all of that makes sence. And don't forget to keep topping the master cylinder up.
https://www.sau.com.au/forums/topic/270992-r32-abs/#findComment-4615567
yup no worries
had a guy of the tassie section help me do it when i upgraded to slotted fronts (and fluid was in a bad way and the abs was leaking too so that got changed)
we did it the same but with the abs first and no order of pref on the order of lines for the abs unit
will bleed again (just abs first) and see how i go
Merli, im not sure what happend cos its been a while but will try on a quiet road tonight and let you know
thanks for the help guys
https://www.sau.com.au/forums/topic/270992-r32-abs/#findComment-4615801
  • 3 weeks later...
bit of a long reply
but...
bled the abs unit again (few tiny bubbles in there)
made no difference at all to pedal length (the length of the soft bit)
was doing 80 on a wet road
STOMP!!!
and the fronts just locked and slid
i think the left locked first tho (but only just)
also
sometimes when braking hard i can hear a grating noise (is this common with slotted rotors?)
https://www.sau.com.au/forums/topic/270992-r32-abs/#findComment-4646434
what do gtrs have?
32 GTR's have a yellow warning light for the ABS... It's with the left hand side warning lights on the top left of the 4 lights there.
Mine lights up on ignition but goes out very quickly - not sure if that is normal operation or not...
Can anyone tell me if the warning light comes on during activation of the ABS?
https://www.sau.com.au/forums/topic/270992-r32-abs/#findComment-4656880
No it doesn't.
Didn't think it did come on, but thought I'd check.. I have recently replaced my ABS unit as well... Gave it one test, and felt the peddle pulse...
No thanks on the gravel road, suspension is harsh enough on normal roads :thumbsup:
https://www.sau.com.au/forums/topic/270992-r32-abs/#findComment-4657011
