R32 Gtr 455rwhp
Item: r32 89 gtr
Item Condition: tidy
Reason for Selling: time to move on to some thing else... maybe build some thing else....
Price and Payment Conditions: 20000 not a cent less or ill just keep her!
Extra Info: r32 gtr 1989 model
rebuilt motor about 10000kms ago
cp pistions rings
acl race series bearings
rev light weight rods
acl race series metal head gasket inlet gaskets
ported poished head matched manifolds
jun bronze valve guides
stainless steel valves
shaved head block ect
fully balanced bottom end crank etc
all new gaskets
new Garrett GT2860R5S 360Hp ball bearing turbos
new radiator
all new rubber hoses
Greddy hard pipe intercooler kit
K&N pod air filters
Sard 720cc injectors
Sard in-tank fuel pump
Re-wired fuel pump
Turbo Smart fuel pressure reg
Jun oil pump
Jun oil pump crank collar
Cam plate covers
Baffled sump
Oil restrictors in the block
Power FC computer with hand controller
E-boost 2
full 3 inch exhaust
Buzz adjustable suspension
Lowered springs
4wd/2wd switch (to make it into rear wheel drive or 4wd without getting out of car)
OS Geiken twin plate clutch
Lightened flywheel
336rwkw on 17 psi 455hp
car has ran a 12.0 181kmh on old stock turbos easy mid 11s car as is...
there would be more i have not thought of.....
no one will drive it until i see a deposit no time wasters!
also comes with 2 brand new 245s semi slicks have not been fitted...
gates race series timming belt new water pump just been serviced to all new fuilds box diff brakes every thing!
its still running a little rich atm 11s afr so its a safe tune! will go 500 at the wheels with a tune up and a bit more boost, makes 455hp on 17 18 psi
also new brake pads and skimmed the front disks new abs unit, pulls up as hard as it goes
pm me
Item: r32 89 gtr
Can you give me a little more info on the 'Tidy' How is body, interior, tyres, paint (any dents/scraps) that sort of thing. Scouring the East Coast for a pearler of a 32 thats had the engine built internally. Much appreciated.
paint is very good few little mark here and there odd tiny dint as you would expect for a 20 year old car..
alot cleaner than most of the ones i looked at when i bought it.
front tyres are cheap ones but 90% i will fit the semi slicks brand new 245s on the rear when i have a buyer rears are worn out done 30 000kms
scratches on front lip and rear bar is fading on a spot was quoted 400 to respray both bars and front lip
so thats why the price is 20 not 25 in side is very clean no rips or tears seat covers all ways on the front
and no one really ever goes in the back
Guest Solman
hey got a few questions,
who rebuilt the motor for you, do you have receipts for this?
when you say "cp pistions rings", does this mean Cp pistons and CP rings, or just the rings? sorry just little confused about this.
the new radiator is it a standard R32 GTR one or after market.
How is the gearbox and diffs have they been serviced lately?
sorry about all the questions mate, i am really keen on a GTR and i am looking at getting one with a rebuilt/forged motor like yours.
thanks again
Edited by Solman
thanks again
no worrys mate gpm local work shop all papers for the build, engine in out, turbos the lot all brand new parts!!! lots and lots of money spent on it!!!!
yes cp pistions and rings!
its a brand new stock radiator 500 bucks never gets hot but put a new one in any way to be safe and all new rubber hoses 550 bucks worth
gear box is fine diff has a slight wind has never got any worse.... both oils have been changed engine oil filter gets done every 3000km! and clean air filters
questions are fine mate any more just ask only reason i am selling is to build some thing differnt time for a change will be a VERY sad day tho if she dose sell :D
sold!
Hi In a ealier thread a few months ago you had oil getting into the coolant. Can you tell me how you fixed this? Im curious to know incase mine starts doing it. Will be running about 1.3-1.4 bar boost and will be keeping a eye on it.
thanks
 Share
    • Ah damn. I might grab one myself because mine works most of the time lol
    • Yes, I mentioned it in my first that I did everything that is mentioned online (Redo dry solders, clean connector between PCB's, etc.) and unfortunately it didn't solve it.  It crapped out again earlier today, so I replaced it. I'll keep the old one around to repair it at some point.
    • I've looked at some oval stuff but still deciding what material to use for the back half to the muffler.   Yeah I do all my own stuff with ecu setup and have it sorted before generally paying someone (my old work) to do base runs and a few power runs then I'll do anything else myself at track or after review data. It's hard to find  a dyno owner these days that will hire out to random.
    • Injectors are told by the ECU to open for certain amounts of time. If the injector flows more fuel, but the ECU doesn't know this, and is told to open for the same amount of time as the stock, smaller injector, then the larger injector will flow too much fuel/more fuel than the engine/ecu is expecting. You absolutely need an ECU to control injectors. You don't need a tune for a fuel pump (because your fuel pressure should remain the same assuming the regulator works). You don't need a tune for an exhaust (the parameters for fuel and air going into the motor have not changed much) You don't need a tune for an Intercooler (the parameters for fuel and air going into the motor have not changed much, it's just the air is cooler) Yes, forum regulars, I know that you really should get a tune for an Exhaust, and Intercooler. These *will* affect the tune, but the stock tune does have some leniency to it with stock AFM and Injectors. Intercooler and Exhaust will fit within this wiggle room. So will running a boost tee to about 10psi, which is a very old way of increasing boost which is not worth doing in 2024. The ECU is vital. It runs the whole show. Most people change injectors and ECU at the same time for this reason. Some people load base maps on some ECU's that have ballpark figures for injector sizing. Sometimes injector manufacturers are really great and tell you what parameters to input into your ECU, which is something you can do with your new shiny ECU. For a beginner, this may enable you to drive to the tuner to have an expert do the rest. Otherwise, you're installing injectors and ECU at home, and paying for a tow to a dyno. Or, you take the car to a workshop (be happy to travel across Melb for the right shop) and someone who knows RB will be able to source/provide/install injectors and tune the car at the same time if they have a dyno or access to a dyno. The reason so many people DIY things here is because finding said workshop is hard, expensive, potentially getting things wrong with miscommunication/other.
    • @robbo_rb180 do you tune your cars yourself or do you send them to someone? If you do it yourself, do you hire a dyno, or tune it after logging it at the track? Meaning like touch ups when you tweak or modify something a bit
