Just saw these starting to pop up on IM over the last couple of weeks.
Don't really see much of a point to them, unless you cannot control your right foot properly.
my problem is takeoff.e.g. My mates EVO9.....standing start he puts 5-6 car lengths on me....rolling start from about 20-30km's I put 1 on him......just takes to long to get going.
Edited by Jetwreck
Put a pianola on his room and see how he goes!
IMO you should wait for the ECU, then if you still can't get him, no harm in trying one. (should smash him though)
Have you got an electronic boost controller? Is the mechanical end of your throttle properly adjusted? Try launching with 5000rev/min (left foot on the brake until takeoff).
No boost controller.....running the standard 14-15psi......Mechanical is good....Yeh used to be able to do that with the standard turbo....new one wont let me.
The point of the electronic boost controller is not necessarily to get more boost but to build boost more quickly and to maintain boost at the top end.
Jets new turbo should boost up pretty quickly and hold max boost to redline all on it's own (I know that my hiflow does :D ).
Edited by iamhe77
These are actually quite interesting and the features are available on some cars as OEM features.
For example, on my wife's SAAB 9-5, when you press the Sport button on the gear shift, not only does it select a more agressive program for the transmission, but also for the drive by wire throttle, with a much smaller pedal movement leading to full opening of the throttle. This really does make the car feel much more spritely, but it also increases the fuel consumption quite dramatically....
Lots of other Euro's have this as well.
Going the other way, Landrovers have the opposite. When low ratio is selected a much less sensitive throttle map is applied to that if the pedal is accidently floored, because you hit a bump when off roading, it does not apply the entire V8 supercharged grunt. Should the throttle be held to the floor, rather then just jabbed, then the requested power will be applied to the wheels..
been looking into manufacturers that make it
those things are brilliant..
they work really well
fly by wire cars have really slow response in throttle..
it's not the matter of controlling your right foot.
a mate of mine put 1 of these things (from toms) the difference it made to the car was amazing.
the repsonse of the throttle imporved sharply
Edited by [[d a n n y]]
If I understand correctly, this doesn't actually give you anything that you couldn't simulate with your right foot, but it just allows you to adjust how far the throttle will be open vs how far the accelerator is pressed down.
In one sense, the sport mode could then be similar to putting your foot down faster on the throttle, reaching full throttle sooner.
Looking at the graphs, it still will not reach full throttle until the pedal is all the way in, but the difference in throttle position between 90% and 100% pedal is much less than without the gadget.
My first thoughts are, for "sports" mode, couldn't you just drive more aggressively? and my concern for eco mode, is that eventually I would "learn" the new pedal feel and my fuel economy would return to normal, due to me using much heavier throttle to compensate...which would then prove troublesome if I were to switch to sport mode after driving in eco mode for weeks.
As for any delay with the drive-by-wire setup, this will still exist because you're not removing anything from the system. The unit just slots in between the pedal and the ecu so any lag that was there before will still be there afterwards.
It looks like a very simple unit that changes the voltage measured from the pedal so that rather than being a straight line graph it becomes a curve. The different modes it offers are just adjustments to this curve.
Any further thoughts on this?
Another thing I was thinking is: how does the ECU handle gear shifts? is this based on pedal position also?
Problem is how quickly the throttle opens.... unfortunately with drive by wire you don't always have complete control over this.....with the VQ25det if you step on it from a standing start the throttle opens very slowly....you are better with a slow squeeze of the peddle....while the car is in motion the power is fine and has hardly any lag, goes like shit off a stick....It's just getting it going from standstill thats the problem.
I do agree but I'm still failing to see how this unit would help. The ecu is going to read either the signal from the pedal (unmodified) or what this unit changes it to. In either case, the maximum pedal amount is still 100% in either case, so for example slamming the pedal to the floor would acheive exactly the same result either way. Its the ECU that decides how much to open the throttle, and this unit is not bypassing the ecu, so it will have the same limitations as the standard setup.
Hope this makes sense? I just dont think its possible to improve the lag situation without bypassing the ecu altogether - which is not likely to be possible or practical.
In a lot of ways I would have preferred if Nissan had still used a cable instead of going with drive-by-wire, since I think the drive-by-wire system seems to have an ever-so-slight delay in responding to pedal movements, especially when the movements are only small. However there are advantages to drive-by-wire (so they tell us). I think it helps the engine to maximise torque when accelerating ?? and it probably helps with fuel economy somehow too...
Personally I find the acceleration to be at its peak in 2nd and 3rd gear, so the acceleration from standing start may have more to do with the gearing than the pedal. The same goes for the lag in any driving situation...whatever communication and logic that goes on between the ecu and the gearbox - I'd love to speed that along a tad. The engine is always ready to take off in its usual ferocity but the gearbox is always a bit over-cautious. When the two are in harmony the acceleration is awesome, but when they're fighting each other it can be frustrating, like there's a secret argument going on and you're the innocent 3rd party that just has to wait and see what the outcome is.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
