yo yo
i got a bit of an annoying rattling sound, i have a r33 gtst,
the area its comin from is like the drivers side at the rear almost near the fuel flap bit maybe even from a suspension part,
the sound is alot like the plastic fuel cap wobbling around when its loose but its not, i hear it most when im just driving around not fast and go over a bump its very noticeable
any ideas?
https://www.sau.com.au/forums/topic/271151-rattle-knock/
Get a louder stereo.
But if it is worrying you go to a suspension place and get one of those $28 safety rip-off checks or whatever they call them and I'm sure they will be able to help you identify the problem. You can then decide to replace it yourself or pay them to do it.
https://www.sau.com.au/forums/topic/271151-rattle-knock/#findComment-4610574
as he said ^^^^^^^^ should be the quickest and cheapest way.....
get under there and just look for broke rubber bushes/mounts, make sure things like the exhaust isnt too close to anything, make sure ur tools int he spare wheel comparment are secured, 90% of rear end noises iv seen r from loose tools and wheel parts
https://www.sau.com.au/forums/topic/271151-rattle-knock/#findComment-4612039
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
