  • Replies 107
G'day,
I'm led to believe that my set turned up in perth on last tuesday.. the office neglected to let me know that they had arrived. Hope to throw them on next week after I get back, and give them a try.
Thanks again mate.
Edited by heller44
Just so everyone knows, the tyres listed are the only ones being offered at this price to anyone on SAU.
SAU:NSW has an exclusive deal with Federal tyres for its members allowing them good prices on any size tyre.
STOCK UPDATE!
225/45R17 595RS – 14 in stock
225/40R18 595RS – 35 in stock (if anyone knows what kind of cars run these, could you lead thim to this thread? THANKS!)
235/40R17 595RS – 17 in stock
Also, have some stuff lieing around we want to get rid of ;) COMES WITH A FREE HAT! :)
215/45R17 595RS – 1 in stock = $110.00
235/40R18 595RS – 1 in stock = $150.00
255/35R18 595RS – 1 in stock = $160.00
265/35R18 595RS – 1 in stock = $160.00
Freight charge on the above tyres = $11.00 (anywhere in Aus).
Hi mate,
I might be keen on some 225/40/18s for my FD race car. :P
What's it gonna cost me for 4 of these delivered to 2290? What freebies will you throw in? :P
James.
PS - I love your avatar.... :-)
Edited by wjp005
These or bridgestone potenzas for rears.
Looking for some grip in the wet.
These are more practical for road use and they also have wet grip where the bridgestone semi slicks are more for the track. As its see you bye in the wet lol, also federals are like 1/3 the price
I meant road potenza's RE050A vs these semis.
Sorry for hi-jacking thread, just a noob question.
Hi DrDoof,
I received your pm but seems I can't reply back anyway with less than 10 post. Can you please give me a quote for 4 federal tyres in 225/45/17 to postcode 4014. Also can you send it to [email protected] so at least I can reply to you there.
Regards
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
