All an electronic controller does is intercept the signal from the throttle pedal, and amplify it going into the ECU (or whatever electronics controls the butterfly). You could do the same thing just by pressing the gas harder. It will simulate better initial response.
I've heard a lot of scuttlebutt that says that the VQ35DE ECU closes the butterfly at higher RPM, regardless of pedal position. If these controllers can fool the butterfly into staying WOT all the way to the limiter, then they're definitely worth it. Every retailer I've asked so far has been unable to answer this for me.
If you're in Sydney and you want to give it a go, give AAI Motorsports a call. They're the official importers of Buddy Club, and they're offering an obligation free "try before you buy" test of their unit.
Attention all owners of cars with drive-by-wire systems. This little gadget aims to remove the laggy throttle response.
Simple Installation: Only takes less then 10 minutes install to virtually any car and 100% reversible.
NO CUTTING – NO DRILLING
TRY BEFORE YOU BUY
We're so confident that you will feel a difference, so call us on 02-9643-5111 to arrange an obligation free test fit on your car.
It lacks the fancy LED of the Pivot unit, but it's adjustable and does the same thing.
I hear that it works by you pressing 20% down on the peddle and it does 30% more so it "feels" like your zipping around.
But thats just what i hear don't know if its true
thats not entirely true. if you full throttle it from a standing start, the ecu doesnt open the throttle all the way. its programmed to be A. gentle to save gearboxes blah blah and B. to give 'maximum' torque all the way through the rev range by not having it at WOT when you floor it and C. for emissions. this device will open the throttle wider than the ECU is programmed to do.
From what I have read on the Sprint Booster it is very different to the Buddy and the Pivot mentioned on this thread. The Sprint is only a single unit plugged in line with no other Black box (no idea what happens in them) fitted as part of the system.
OK, if it opens the throttle more than otherwise possible it could perhaps be worthwhile.
Sorry, but the buddyclub looks like it works exactly like the sprint booster.
FYI, the sprint booster when sold about 3-4 years ago for my cousin's GTi also had a "try before you buy" promotion, because participants are easily convinced that their car seems to have much improved throttle response, akin to installing a much lighter crank pulley or something.
But anyway this buddyclub throttle reponse box looks like the throttle response can turned on and off and can be adjusted to your liking, so it seems much better buy than the sprint booster. How much is it going for? A sprint booster used to be sold for $400 for almost any e-throttle car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
