Hey all, SEI are having a small meet next friday. not many casual meets going on round here so i thought its time for me to organise one. everyone is welcome so bring friends if you want
when: Fri 29th may 8pm
where:
* monash uni car park (multi lvl that you can see from wellington rd)
* then we'll head to spaghetti junction - the intersection of princess hwy, springvale rd and center/police rd. the place is just up the service lane from the kfc.
* we can decide from there if we are gonna cruise or not. if we do, i have a route in mind that'll do.
https://www.sau.com.au/forums/topic/271259-sei-kebab-run/
  • Replies 340
what is sei? i might be in for this one
South East Imports. A club for all import drivers, rather than a particular type of car :P Mind you, it's 90% SAU members anyway.
www.southeastimports.net
Edited by jezza boii
https://www.sau.com.au/forums/topic/271259-sei-kebab-run/#findComment-4611034
Ok, so far...
Confirmed:
Basti - black R33
(OO)SKYLINE(OO) - gunmetal R32
krzysiu - orange R33
jezza boii - black MR2
lil_lucky - black R32
eMsta - R33
Maybes:
RBPOWA - white Stagea
https://www.sau.com.au/forums/topic/271259-sei-kebab-run/#findComment-4612369
Guest
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
