  • Replies 340
  Basti said:
woulsa come if i saw this. got drunken sightly with mates
edit : was answering jez
Man, you missed out on the best night EVER. Started off at a house party then went to the city. Loft was actually good for once. Sooo many hot girls and they were all over everyone.
Got a lift home from this chick with the mandatory Maccas run on the way home.
  GT-R 32 said:
yeah i was hanging for a kebab tonight.. settles for larpoghetta :P haha
Who has joined SEI forums here?
haha im will join... im just waiting for the right moment to do it :P
There's about 20 SAU members on there already. If everyone actually started talking on there then it could actually be good :D
Meets are always big, but forums are dead a lot of the time.
  RBPOWA-(TJ) said:
lol when you said that, i went over and checked.
last post was 2hours old haha woah fully active brah !
LOL that IS active for SEI. We've had dry spells that last like 10 days.
Me and Chad used to be the only ones that post but now Basti is getting active so everyone else is jumping onboard :P
I'm satisfied with the meet side of things, but the forum needs more topics to get the ball rolling.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
