239rwkw
oh yeah
1997 Series 1 Nissan Stagea RS V Four Station Wagon, 106,500kms, Auto, RB25DET engine, Attessa 4wd, Silky Snow Pearl, Dayz bodykit, Fresh fluid throughout, 100,000km service done incl. new water pump, belts, exhaust studs, all fresh fluid throughout such as p/steer, radiator, attessa, diff, gearbox, engine, brakes, etc.
Engine:
Ryco Z201 fuel filter, Ryco Z145 oil filter, Ryco Z160 turbo oil filter
Davies Craig automatic transmission oil cooler upgrade kit
MV Automatic shift kit & auto service kit
Koyo Radiator upgrade
Splitfire coil packs
NGK BCPRE6 0.8mm copper v-groove spark plugs
Bosch 040 fuel pump with direct battery feed at 13.8volts
Greddy remote oil filter relocation kit & Fujimoto sump plug drain valve
Garrett turbo oil return filter relocation adapter kit with oil pressure & temperature sensors
Catch can kit
Nismo adjustable fuel pressure regulator
Nismo Z32 Air Flow Meter
3inch JustJap stainless steel single dump pipe system (turbo to cat)
3inch high-flow metal race cat
3inch cat-back exhaust system with Magnaflow 4" barrel mid-muffler & Kakimoto GTR Racing rear-muffler
Cold Air Radiator air guide (feeds radiator / pod / intercooler)
Cold Air Induction aluminium box w/ lid setup, foam internals, using standard snorkel air feed
Trust 600x400mm FMIC bar & plate, with custom hard pipe kit
Apexi power intake pod filter, with custom hard pipe feed & hard pipe intake to turbo
HKS heavy duty turbo actuator
Garrett GT30/T04S 700177-3 IWBB Turbocharger with ported Nissan 45V4 front / AVO .73 rear housings
Ported & Machined headwork including new valve seals, valve seats and valve guides
EPP Clear camgear timing cover
Cometic gasket kit including rocker cover, intake manifold, intake collector & exhaust gaskets
Cometic head gasket 87mm x1.2mm
ARP head stud kit
Aerospeed adjustable exhaust cam gear pulley wheel
Tomei 256 intake / 256 exhaust poncam gear set
Tomei 8.8mm high lift springs
Tomei oil gallery restrictor
Suspension:
Bilstein front and rear suspension shocks, with ‘lowering’ circlips, using standard springs
Whiteline front and rear adjustable swaybars
Dayz adjustable engine swaybar, custom boot swaybar
Whiteline front castor kit
Whiteline rear subframe alignment kit
BJR Graphite 17inch rims with Marshal Mactrac TX tyres, 235/45/17
Brakes:
Maltech stainless steel braided brake lines, front and rear
DBA slotted front brake discs
Benidx Advance front and Heavy Duty rear brake pads
Audio:
Clarion stereo tape unit with 6-stack cd player
Clarion amp mounted to enclosure for Clarion 10inch subwoofer
Pioneer 260w 4-way front door speakers
Eclipse 80w 2-way rear door speakers
Razin volt stabiliser kit & car alarm
Interior:
Ghepardo reclining racing seat
Flynn racing seat rail
3x 2" DIN gauge setup including boost pressure, oil pressure & oil temperature
Apexi electronic boost gauge
Apexi SAFC Super Air Fuel Computer
Apexi SITC Super Ignition Timing Computer
Greddy Profec-B spec-ii dual stage Electronic Boost Controller, set to 0.9bar and 1.1bar
Toshi ecu remap, tuned by Boostwerx
239rwkw
https://www.sau.com.au/forums/topic/271277-babys-got-back/
nice work... were did you get turbo from? full boost at what RPM?
Would like to see some pics of car.
got a sore back atm so havent really given it a beating yet.
will let you know rpm vs boost via pm next week
turbo is a GT3076 from ATS Adelaide Turbo Services, boost of 1.1 bar at around 3800 ?
Nick, cheers
can you embed the youtube?
https://www.sau.com.au/forums/topic/271277-babys-got-back/#findComment-4611076
Brendo, just when I thought the fantasies of you couldnt get any hawtter :P
Oh, and heres one we prepared earleir (seeing as though our great hairless mod is slow on the uptake :D )
https://www.sau.com.au/forums/topic/271277-babys-got-back/#findComment-4611090
thanks Sweetness & Light
https://www.sau.com.au/forums/topic/271277-babys-got-back/#findComment-4611114
internal gate im guessing? could you post link to turbo on ATS website if they have one.
GT3076 Ball Bearing internal wastegate, using ported stock Nissan 45V4 front housing, garrett core, AVO .73 skyline rear housing
no website sorry
all up cost of $2200 with lines, for me as I gave him a td05h wheelset
https://www.sau.com.au/forums/topic/271277-babys-got-back/#findComment-4611134
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
    • 😂 thanks guys. The diagram i had did not have the breather on it at all. Much appreciated.
    • Geez, engineers fees have definitely gone up. Mine back 2007 cost me all of $300. Mind you, I had to go back to him a few times to get him to write the correct things on the report after he'd inspected it. Things like wrong exhaust size, wrong wheel sizes, etc etc.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
