239rwkw
oh yeah
1997 Series 1 Nissan Stagea RS V Four Station Wagon, 106,500kms, Auto, RB25DET engine, Attessa 4wd, Silky Snow Pearl, Dayz bodykit, Fresh fluid throughout, 100,000km service done incl. new water pump, belts, exhaust studs, all fresh fluid throughout such as p/steer, radiator, attessa, diff, gearbox, engine, brakes, etc.
Engine:
Ryco Z201 fuel filter, Ryco Z145 oil filter, Ryco Z160 turbo oil filter
Davies Craig automatic transmission oil cooler upgrade kit
MV Automatic shift kit & auto service kit
Koyo Radiator upgrade
Splitfire coil packs
NGK BCPRE6 0.8mm copper v-groove spark plugs
Bosch 040 fuel pump with direct battery feed at 13.8volts
Greddy remote oil filter relocation kit & Fujimoto sump plug drain valve
Garrett turbo oil return filter relocation adapter kit with oil pressure & temperature sensors
Catch can kit
Nismo adjustable fuel pressure regulator
Nismo Z32 Air Flow Meter
3inch JustJap stainless steel single dump pipe system (turbo to cat)
3inch high-flow metal race cat
3inch cat-back exhaust system with Magnaflow 4" barrel mid-muffler & Kakimoto GTR Racing rear-muffler
Cold Air Radiator air guide (feeds radiator / pod / intercooler)
Cold Air Induction aluminium box w/ lid setup, foam internals, using standard snorkel air feed
Trust 600x400mm FMIC bar & plate, with custom hard pipe kit
Apexi power intake pod filter, with custom hard pipe feed & hard pipe intake to turbo
HKS heavy duty turbo actuator
Garrett GT30/T04S 700177-3 IWBB Turbocharger with ported Nissan 45V4 front / AVO .73 rear housings
Ported & Machined headwork including new valve seals, valve seats and valve guides
EPP Clear camgear timing cover
Cometic gasket kit including rocker cover, intake manifold, intake collector & exhaust gaskets
Cometic head gasket 87mm x1.2mm
ARP head stud kit
Aerospeed adjustable exhaust cam gear pulley wheel
Tomei 256 intake / 256 exhaust poncam gear set
Tomei 8.8mm high lift springs
Tomei oil gallery restrictor
Suspension:
Bilstein front and rear suspension shocks, with ‘lowering’ circlips, using standard springs
Whiteline front and rear adjustable swaybars
Dayz adjustable engine swaybar, custom boot swaybar
Whiteline front castor kit
Whiteline rear subframe alignment kit
BJR Graphite 17inch rims with Marshal Mactrac TX tyres, 235/45/17
Brakes:
Maltech stainless steel braided brake lines, front and rear
DBA slotted front brake discs
Benidx Advance front and Heavy Duty rear brake pads
Audio:
Clarion stereo tape unit with 6-stack cd player
Clarion amp mounted to enclosure for Clarion 10inch subwoofer
Pioneer 260w 4-way front door speakers
Eclipse 80w 2-way rear door speakers
Razin volt stabiliser kit & car alarm
Interior:
Ghepardo reclining racing seat
Flynn racing seat rail
3x 2" DIN gauge setup including boost pressure, oil pressure & oil temperature
Apexi electronic boost gauge
Apexi SAFC Super Air Fuel Computer
Apexi SITC Super Ignition Timing Computer
Greddy Profec-B spec-ii dual stage Electronic Boost Controller, set to 0.9bar and 1.1bar
Toshi ecu remap, tuned by Boostwerx
239rwkw
https://www.sau.com.au/forums/topic/271277-babys-got-back/
nice work... were did you get turbo from? full boost at what RPM?
Would like to see some pics of car.
got a sore back atm so havent really given it a beating yet.
will let you know rpm vs boost via pm next week
turbo is a GT3076 from ATS Adelaide Turbo Services, boost of 1.1 bar at around 3800 ?
Nick, cheers
can you embed the youtube?
https://www.sau.com.au/forums/topic/271277-babys-got-back/#findComment-4611076
Brendo, just when I thought the fantasies of you couldnt get any hawtter :P
Oh, and heres one we prepared earleir (seeing as though our great hairless mod is slow on the uptake :D )
https://www.sau.com.au/forums/topic/271277-babys-got-back/#findComment-4611090
thanks Sweetness & Light
https://www.sau.com.au/forums/topic/271277-babys-got-back/#findComment-4611114
internal gate im guessing? could you post link to turbo on ATS website if they have one.
GT3076 Ball Bearing internal wastegate, using ported stock Nissan 45V4 front housing, garrett core, AVO .73 skyline rear housing
no website sorry
all up cost of $2200 with lines, for me as I gave him a td05h wheelset
https://www.sau.com.au/forums/topic/271277-babys-got-back/#findComment-4611134
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
