I have my Hiflow for sale as i am going a bugger turbo to suit my 30DET.
I bought this turbo from new from Sliding Performance and fitted it to my RB20DET. it is a cracking turbo and started a bit of a revolution on the forums. It has done around 30,000 k's and is in good condition. it is designed to fit an RB20DET or RB25DET and will produce enough flow for 240rwkw on a 20det and possibly a bit more on the 25det. it comes on like a hammer and pulls to redline. please have a look in THIS THREAD for the whole installation diary and performance figures.
it comes with an RB25 elbow and an actuator. it will bolt onto your standard manifold. no modifications needed. I will also supply the needed oil feed bolt, but you will have to have your oil line restrictor removed.
$500
I also have a stainless split front/dump for sale to suit this turbo. it is made by BOS importing BATMBL. do a search. these are the best dump front pipes you can get for a stock turbo.
$250
both located in Melb. would prefer not to freight the front pipe.
cheers!
turbo is sold...
the stainless front/dump pipe is still for sale. these are the best dumps you can get for a skyline.
$250 :/ thats the same price as the copies you get from just jap.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
