Hi guys,
Installed a powerfc and have some problems like some S1 stag's are having, though the pfc should be plug an play (to a degree) with my R34 GTT.
Done some checks and found the following
- Voltage for the throttle motor sensor (pin51) is approx 4.62v.
- Voltage on pin 23 when car is on ignition 0.01 to 0.02 fluctuating,
- Voltage on pin 23 when car is idling is 0.00
- Voltage on pin 37 is 0.00 at ignition and idle
- Voltage on pin 53 is 0.00 at ignition and idle
- Voltage on pin 79 is 0.00 at ignition and idle
I've been told they should be as the following
Pin 23 should be 0.5v approx idling
Pin 37 should be 0.5v approx
Pin 53 should be 4.7v
Pin 79 should be 2v approx
Pin 51 should be 3.4v
symptoms are the following - A/C compressor wont turn on, TCS, SLIP and MIL lights on. powerFC sw sensor check has the THR black background
Im quite lost as to where to look and why so many pins are having no output.
Any idea's where to check?
https://www.sau.com.au/forums/topic/271370-er34-vs-stagea-s1-pinouts/
Hi guys,
Series 1 stagea's there are 3 different wiring pinouts/ecu's. I have a series 2 stagea with the neo rb25 and did use a power fc for a while with no problems except for the engine check light which comes on due to no traction control on awd stagea's.
I am a bit unclear to what car/engine combo you have? Is it a stock R34 with the original neo engine, or have you fitted a series 1 stagea engine to it?
Hey mat,
sorry I should have specified. The car is a R34GTT (ER34) manual with the original neo rb25det. Unfortunately I never had a stock ECU, just an Impul replacement. The impul unit when installed runs fine and no error lights on the dash. a/c TCS can be turned on and off as normal. then switch the loom back to the PFC with the problems as above :)
Cheers
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
