Hey guys ,
Im feeling the mod bug and After my research i have decided on :
PERFORMANCE : MOTORDYNE SPACER 5/16"
K&N DROP IN FILTER
Z-TUBE
EXTERIOR : CLEAR CORNERS
I currently have a Fujitsubo exhaust system im told i have high flow cats .Can someone tell me how i can comfirm this i have no idea what they look like. I have the impul ecu installed which nobody can tune. Another question after i install these performance mods i read im suppose to re-tune the ecu do i have to do this as well. I did i dyno run (161.4rwkw ) and the guy said it's running alittle rich at the end so i figured added this will even itself out am i right ?
Also got the nismo lip kit , recaro seats , advan 151c 19" wheels.
Where is the cheapest place to get all this? Riverside infinity? everythingg35 ? And with the k&n filter im really keen on getting that whitlsing sound will i get it ? Does anyone else have any idea what i should invest in appearance wise ? i was thinking about a rim change my pic below .
How much is those sway bars and whats the best one to get and from where ?
Thanks in advance .
Edited by manda23
https://www.sau.com.au/forums/topic/271392-best-mods-1000aus-to-spend/
  • Replies 87
about the whilst sound, i installed my JW intake, and is having that sound, BUT I am not sure if it is caused by a leak or wat, as i installed it myself (i m still a beginner!!) performance gain? MOST people will say there is NONE.. read more.. on this forum or G35driver.
yeah i read about the JW pop charger . I know with this alone no performance but combined with spacer and z-tube i heard good things!
i Do hv the spacer and cf tube in.. erm.. do i 'feel' a gain.. ? i m not sure too..
mayb coz i don hv a new ecu yet.. trying to source one but not sure which is the most suitable choice..
You will not get the whitlsing sound from the K&N drop in filter. Combo of the spacer and JWT on my V35 was a total of 15kw gain to the wheels. But I do need to re-tune the ECU to get full benifit from my mods.
Watch my vid to hear the JWT filter with Z tube and Spacer.
thanks im just bored with them. But what about the performance parts where do i get them how much should i be expecting to pay?
$400 for a spacer $400 for JWT filter and Z-Tube $60 for clear side markers :)
i have over priced
i have over priced
Thanks Paul . I heard the jwt filter has some problems with over heating or something about heat soak . Do you know what they mean ? I guess the spacer at riverside inifinity at $220us is the cheapest . Is there any other mods you can suggest either in performance wise or appearance? How can I tell if I have high flow cats ?
Because the Z-tube is plastic heat soak is not bad at all and some people don't put the heat sheild on over the pod filter and that then sucks heaps of hot air in.
Skunk2 spacer is the easiest to put on.
Don't know about the high flow cat (look under the car does it looks differnet to others?)
Strut Brace then ECU upgrade is the next thing for me
My body kit looks good :) "Ken Stlye"
Custom paint or Turbo/Supercharger will be on the list if money comes my way.
I'm not worried about install going to get the pros to do it. And with thepop charger might just stick with the drop in filter I don't want to be putting heat shields. As for super charger would love too but don't have the paper work for it .
Thanks for your input Paul
Have youhad a power run with your mods on yet?
hey manda23 that front lip on your car isnt the nismo lip it is actually just the factory nissan aftermarket lip... correct me someone if i am wrong.
I'm not sure . Someone told me I have the nismo
lip kit with includes the front lip and the rear spolier . I have no idea what the difference is.
What price do you think I should sell my wheels for they are pretty rare on our shores and fit our car perfect. I wanna get some volks for a change of looks I'm tired at looking at the same thing.
Are you serious ? Which spacer do you have and do you still have the factory air filter I read people are getting between 10-20kwatts from these modifications
Unfortunately Blistc is right on the money there...
Whoever told you got Nismo stuff don't know the difference between a hazelnut and an almond nut.
You have factory nissan front spoiler and factory nissan rear spoiler. I'm actually ordering that exact front spoiler from japanparts, but i'm not getting the rear spoiler. not a fan of wings, really.
here is factory NISSAN rear spoiler:
and here is NISMO rear spoiler - elevated with gaps between the boot and the wing... you can tell the difference straight away....
factory Nissan front lip = what you have
NISMO front lip - the protruding lip section is smaller and 'sharper' towards the bottom of the lips, and there was no curving up on the rounded corner of both sides that wraps around the bumper...
177KW at the wheels. best run was 178kw but could not get 2 runs the same
Paul,
Doesn't the stock v35 pull 170kw at the wheels?
What did you have at the wheels before the spacer and jwt?
I want a performance upgrade as well...but there doesnt seem to be anycost effective options for the v35!
    • I'm at the point of seriously starting a project to build and Arduino/mc (of some sort) based multigauge to go in the console where triple gauges normally sit. I have found a screen of the right dimensions. I would need to 3D print a bezel/housing to make it mount up pretty. That's doable. I would need to come up with interfacing circuitry for the EGT thermocouple. I'm sure there will be examples of that into Arduino out there somewhere. Ditto with characterising the output of the existing boost gauge's MAP sensor and the oil T gauge's thermistor. And then, because it is a screen, it can be controllable, so it can show more than the 3 gauges I currently have. So I can come up with a list of other things I want to be able to show on it that can be reasonably easily handled via an Arduino's inputs. I do not need this project. But the stepper gauges I'm using are giving me grief. It's time to come kicking and screaming into the 21st century.
    • Would you really prefer pillar gauges over something like this? https://www.haltech.com/product/ht-067010-haltech-ic-7-digital-dash-kit/ Or if you can spend more, this? https://www.haltech.com/product/ht-068000-haltech-uc-10/ I could write a thesis about how much better a modern dash is compared to a series of gauges.
    • People think it's a waste of space, ugly, etc, generally associate "emissions control equipment" with "bad". These OBD1 vacuum-only systems I'm not a huge fan because I think they don't go far enough. They're wasting some of the fuel captured because they start purging as soon as the engine pulls vacuum. Later OBD1/OBD2 they put an electric purge valve on them to vent only when closed loop is active so the ECU will trim some fuel out. Even later OBD2 with zero evaporative loss the tank is 100% sealed from atmosphere until you run the engine or press the refuel door release. The tank has to take much higher vacuum/pressure spec but you never deal with saturating the charcoal canister and losing some fuel that way. The fuel also lasts as long as it would in a 100% airtight container which is nice when you're dealing with modern E10 pump gas.
    • If your luck is anything like mine, what happens is in the process of pulling hoses to get access to the one leak you create many more leaks because every o-ring was on the verge of failing and the strain of pulling it apart caused it to fail. Sometimes life is simple, sometimes you pay twice trying to save once. For the R33 you can still get most AC components from Nissan, I use nissan epc data or amayama to look up the part numbers and then search for the cheapest/most practical way of sourcing from there.
    • The dirty secret is there is nothing recyclable about the plastic bag or old plastic bottles either. Our local trash collection explicitly calls it out as hazmat in both cases. Oil-soaked rags + paper towels too. Oil-soaked cardboard is also not recyclable. The most common case of oil-soaked paper like that is pizza boxes, which are explicitly compost-only from the oil. To my knowledge hazmat oil contaminated plastic the only solution is either landfill or "thermal recycling". Most plastics in my experience there is slow permeation of the oil it's holding into the container so it's very challenging to get it 100% clean.
