have you thought about running the external gate from the exhaust housing? i done that with my turbo and $250 50mm gate and its perfect. holds whatever boost i set it at with no creep at all
unfortunatly not adriano, just 1 side. hence different back pressure against front 3 from back 3. I was going to run a spacer between the manifold and the turbo with a gate on it but i do not have enough room.
and I would rather bugger a manifold worth $40 than a turbine housing. also if i have to i can easily enough swap over the manifoldback to a non gated one if i have to.
some have mentioned the possinility of tapping a thread in the manifold and screwing a 50mm pipe in the thread that the gate comes off. this looks like a good ideal as welding cast iron is a bit of a hit and miss operation. I have a mig but my skills are not very good yet and i would most likely crack the mani even if i preheated it.
I am going to install the gate on the manifold so it feeds off both sides of the seperator. i really dont need it to come on boost earlier :D i like the way it comes on now.
can you explain a bit? where would the gate go? and what wouuld ot feed from Cheers"
I thought about doing that but the plumbing would be above what i can do due to the cast welding.
so i am going to stick with the manifold gate :D
results in 2 weeks poeple!
UPDATE:
My replacement stock manifold arrived and so did the new wastegate. I bought 2 90deg long radius steampipe bends from reece plumbing.
The manifold has been drilled on both sides of the devider and I have cut 2 elongated ports and filed them smooth but leaving the devider intact. the steam pipe was then cu to suit the profile of the manifold and tacked in place the 2nd elbow was welded to the first in the right orentation and the gate flange welded to it.
I then welded the new gate pipe to the manifold. I was going to get it done professionally but decided to attempt it myself as i really wanted it finished thes weekend. I cleaned the manifold and gate pipe with a wire brush and used flux core gasless wire to weld it as the flux apparently helps bind the mild steel and cast iron. I fed quite a bit of heat into it and used 130amps and kept a HUGE weld pool. did it in 3 passes and it looks fairly strong. will wait and see once it has cooled down :domokun:
so the manifold is now done and will go back on the car tomorrow after it is cleaned up and painted...
well so much for stock looking car :/ I was really hoping to get away with the internal gate but the external was always going to be the better option.
Manifold is now on! the external gate sounds evil :thumbsup: looks like it holds boost very well. the 12psi spring seems to hold boost just fine just using the side port and leaving the top port to vent to atmosphere.
photos will be coming later tonight!
cheers!
once i have had a chance to to a nice WOT in 4th and i am satisfied it holds boost flat it will be a trip back to the dyno and finally some results. I will try and book some time this following week if i can. probably needs about 2 hours more tuning.
the ghetto boost line will be fixed. i just ran out of hose and used what i had laying around, it will run from the plenum across the back of the firewall to the gate. I still dont have the screamer plumbed into the exhaust. i am going to get some 1&1/2" mandrel bends to do it properly but i think i will drive it around like this for a while to frighten small children :P
Adriano,
I looked at it for ges and no, the manifold would be hacked to buggery to do it. I really wanted to do it that way but nevermind :P
CJ, Will do! I will mount the camera and go for a drive over the next couple of days!
Adriano,
I looked at it for ges and no, the manifold would be hacked to buggery to do it. I really wanted to do it that way but nevermind ;)
where are these videos.. Im also using a hx40w, 16cm2 exhasut side on my l28, Also convinced my mate and found him another hx40 16cm2 for his rb25det.. :happy:
yeha I will get there :P
too much on the go at the moment, I have jsut finished rebuilding a CBR600R and now have to cafe racers is bits in my garage. it never ends, i have kind of given the car a break for now but will finish this soon,
The car is on the road and daily driven at the moment when the gate opens it breaks traction HARD! its pretty loud!
has anyone else got any figures from these turbos on RB's yet?
Sorry, we have a typhoon here right now so no vids for the next couple of days. Soon though, I promise. I've got a couple other people asking for them on another board also, so I'll get to it soon.
CEF, what kind of figures are you looking for? HP/dyno/track numbers I assume? Best place for that would be the results thread the DSM guys have put together here but those are mostly 2.0L 4G63 motors, so it's not apples to apples.
Would be good to see some actual dyno figures for a Holset on an RB, as much fun as it all sounds any semi-decent reasonable sized turbo makes for a fun drive on an RB25 :P
Would be good to see some actual dyno figures for a Holset on an RB, as much fun as it all sounds any semi-decent reasonable sized turbo makes for a fun drive on an RB25 :)
fingers crossed we'll find out soon with nish's car
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
    • I'm always a glass half full kinda guy. This will be a great project and the finished product will be awesome.
    • A local that insisted he learned from the best in Australia for RB builds managed to machine a head past the point of saving according to another shop and it dropped a valve too. Ghosted the customer and as far as I know nothing really happened to him. A coworker also recently told a story about owning a Porsche in Germany and running into issues with a dealer tech leaving scratches, oil stains, and missing parts all over his car. I'm not a master tech by any means but at this point I've seen enough expensive mistakes that I'd rather make them myself.
    • 12 months on the pump would be great! The pump is really not that old, I have a receipt from when it was purchased new and it's done ~25,000km since then. it really should be okay. And if it it's not, well. I figured I'd at least run it out as it's already tapped for the nissan temp sensor sticking out of it. Here it was, ready to make it's journey back into the bay, though the balancer had to be tightened/seated more. And it was very stubborn to sit back. So much so that the crank bolt ended up stripping inside the crank instead of the balancer moving to it's intended location.
    • There are professional butt-monkeys too. Just from lack of familiarity in Europe and the US there are plenty of mechanics who do things the wrong way on RBs. Even here in Oz, where we've been playing with RBs since 1986, there are still examples of the not-quite-bright-enough mechanic doing the wrong thing and causing simple jobs to go wrong.
