  Russman said:
Good work everyone! Consistency to gets ya up the front.
Apparently it's not all about Long Wangs ay Russ? :dry: I thought you had me stitched up for sure this time!
Congrats to the weeners too, especially chris and Ryan for touching up the porkers
  • Replies 156
What a great week end. Loved every minute of it. That was my first SAU event and was not dissapointed at all. Great event, great people, and great big f**king drinks. Will be back again for sure. Thanks to everyone involved with organising the day. And to everyone who gave me driving tips. I was only driving poorly so that it would be easier for me to improve next time. :dry:
Thanks again.
BrendanR33
(Putting Wodonga on the SAU map since 2009)
some gopro clips (make sure you use HQ). front bar cams turned out ok...
http://www.youtube.com/view_play_list?p=F251C939AD648EFC
Again a great day. Well done to the team for organizing another event.
lol at group 2 on the long wang with the bus stop.
great pics from marty and crew again.
  dave1200 said:
Apparently it's not all about Long Wangs ay Russ? :P I thought you had me stitched up for sure this time!
Apparently not :D Long wang is the only event that I don't try to slide.
One day I will drive sensible and not sideways. It will take a lot of self control though. I don't like being beaten by a car with saggy balls...:)
Heya guyZ,
Had an absolute blazt popping the [R]'s cherry and mine at my 1st DECA event. Certainly like to commend the efforts of all that made it possible on the day; thanks and well done on a flawless day.
Am now watching the clock for the next DECA event! :) HURRY UP
Wasn't thinking about the points when I decided not to run the last battle - doh ma! Oh well, look forward to dialing her in again with the next Deca now that tyres are scrubbed and will remedy handbrake.
Thanks to those who also went to the exent of taking photo's n videos as well!
Cheers,
Ben
Congrats to all and a big thanks for the vids and pics.
Can't believe that I finished in the top ten the first time that I've done DECA in the R :) but I didn't go for the points so that was just a bonus.
Oh and Martin everyone think my GTR is purple but it is actually black from the factory :P
    • Welcome!  How long have you had it? And what colour is it?
    • "CAD" version 1.0 It will have a 15mm lip around the top for 6 × 5 or 6mm nutserts and fixtures (two on each of the three straight edges), and some pinch weld on any exposed edges, it has three mounting points, one of the power steering reservoir bolts, and two on the rad support, my 120mm hole saw will make short work of hole for the silicone joiner, with ample room for some pinch weld  I've also got enough Carbuilders "peel and stick" heat shield to cover the outside of it at the coolant expansion tank and on the engine side, as pictured, and internally on the lid and where the fuse box is, I've also got some thin, about 3mm, black 3M single sided sticky foam stuff that was left over after sealing some door drafts at home to help seal the lid As for the shape, it "sort of" matches the shape of the fuse box, so shouldn't look to "out of place" The lower area and hole for the intake will need pinch weld with a balloon on it to fully seal the hole and bottom of it, that will happen after it has been fabricated so I know exactly what size is required  Filter service has been trialed,  and so far it was a simple process  Just need to get some alloy, and then head into work to use the guillotine and break press in the workshop Hopefully it should be sorted in a week or two Guestimated outlay will be under a $50 for the stuff I don't have on hand (alloy, 6mm nutserts, the pinch weld, and wrinkle paint) Disclaimer: That's what the "voices in my head" are telling me how the filter box should end up getting done......lets see if they know what they are talking about
    • Have been polishing up the trailer rims as they had been sitting in the shed for a few years and are really in need of some love. This was after a couple of passes with chrome polish - coming up quite well ✅ .
    • Welcome aboard! Is your Skyline auto or manual? I'm assuming manual. Does it have any mods done yet?
    • Hey mate, the brown and grey plugs would usually go to the TPS, brown one goes on the bottom connector and grey is the top but isn't used unless the car is auto, your TPS looks different to mine though I've got a series 2 engine.
