I'm looking at replacing my old system(its not original either) , with nothing flash but a slight upgrade.
So.. I want it to sound nice but dont want to spend alot. And it has to take USB mp3s, as I dont use cds anymore.
Thoughts were spending $200-$300 on a nice head set (with usb) thats grunty enough not to need a amp. And using jaycar 6.5 kevlars coaxils front and rear. I was going to put some sound deadner in the doors and not worry about a sub.
Are the original speaker wires ok or is it worth the upgrade? And is a amp really worth the $$$
Those of you that have already done systems in 2 door r33's i appriecate any ideas and comments.
Esp head set and speakers selection.
thanks guys
https://www.sau.com.au/forums/topic/271513-modest-sound-system-for-r33/
I don't own a 33, but I did my system in my 32GTR and its a pretty descent setup.
I think most of the headunit can drive about 50w each channel (4 speakers).
Cheapest and quickest option would be to get any name brand headunit with USB MP3...etc and wire it up using the stock wiring. You should be able to just use the factory wiring and the HU can drive the front and rear no problem. Then get dynamat extreme and deaden both doors and the rear passenger area (under the B/C pillar trim). The only complicated part would be to make the speaker adaptor for the doors.
To go a bit better, get a descent HU with at least 2v RCA pre-out for front, rear and sub, for future proofing. If you want to get an external amp (a descent one), which you might as well do everything else and install a sub.
Hunt around eBay and the FS section in this forum, some of the used sound gear come up cheap and you'll save a bit of money going 2nd hand.
Oh and can I buy a single plastic DIN filler from any shop or do I have to go to Nissan?
You mean you have a spare din not in use? Just get a single din pocket and put it in there. Most audio shops like Ryda stocks them. Does not has to be nissan.
Edited by __PhaseShiftDown
So far Ive bought and installed a Pioneer usb head (thanks to jb's sales) and the jaycar 6.5 kevlar's just in the front.
Got the blank DIN and jap ariel adaptor from autobarn.
I got the 6.5s to fit with the door standard speaker mounts(with a bit of moding), and drilled the door plug to pull the cable thru.
Sound really good, still want to put put the jaycars on the back and maybe put some deadener in the door.
thanks for the advice guys.
Stock speaker wires should be ok, and sound deadener in the doors will definitely improve the bass. Try and seal the door enclosure with some rubber or similar material from Bunnings etc - cheap and works a treat!
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
