I just found out my manual turbo r33 that I just bought was a converted AUTO. It has the the auto ECU, and looking at the specs the auto makes less power then the manual. Can I swap the ecu for a manual one or are they the same?
I think it still has the auto 4.4 diff also.
https://www.sau.com.au/forums/topic/271517-r33-auto-vs-manual-ecu/
known differences
- dash cluster
- ecu
- diff gears
- turbocharger actuator
the auto runs less boost (lower rated spring) so make sure you fit a boost controller (or change the actuator)
from memory the auto runs about 4psi and the manual runs 7psi so definetly a difference worth fixing
known differences
- dash cluster
- ecu
- diff gears
I call BS on the boost thing. My auto GTS25T runs a solid 8psi. Factory ecu, factory boost solenoid (earthed to keep it at high boost).
  • 3 weeks later...
ran a auto ECU when i done my conversion for years. put a manual ECU in at the end of last year, the only thing it did is clean up the idle a little and a bit nicer power curve.
did you need to do anything special for the manual ecu? I mean did it just plug in and go ? and were you able to remove the auto computer afterwards?
just unplugged the auto computer and plugged in the manual. have got a SAFC2 and had that retuned on the dyno. if the car is stock, it shouldnt be a problem. just plug it in.
the auto acutator has a different spring, thus it runs less boost
i have seen this with my own eyes in an auto R33 GTST
i suspect they just made it run less boost to make it not as quick and attractive
and perhaps to make it more nimble when driving it? maybe those who wanted auto cars in japland didnt want fast ones?
i mean were only talking 2 psi, but its a bit of difference i guess
and if you would like to double check, in case you think im wrong (haha?)
then check the R33 nissan service manual
r33_engine_manual.pdf
page 173 of 491
or EN-153
r33 auto boost = 270mmhg = 5.22 PSI
r33 manual boost = 385mmhg = 7.44 PSI
crap -so i'm missing out on 2 psi?
that is ALOT if im only getting 5 psi.
My factory gauge reads about a 2-3mm below the middle line.
Suppose I should get a cheap temp boost gauge to check it , and if it low then get a bleeder.
thanks for the info guys
page 173 of 491
or EN-153
yeah this is exaclty what the auto does on max boost full load
on the stock guage it reads below the middle line noticbly below
the manual gtst goes above the middle line
its a fair difference
you would find it better to do basic stage 1 mods though...
exhaust
intercooler
boost to 12psi
interceptor device (safc, piggyback, remap)
the car will run loops around the factory setup
  • 1 month later...
im still not convinced. Is that manual for S1 or S2? Everything i have read, and tested points to the S2 (atleast) running 6psi/8psi factory boost, using the dual stage solenoid. Earthing that solenoid makes it run 8psi all the time. Thats regardless of if its manual or auto.
Ive driven two auto 25Ts now, and both have done 8psi (one is my own one, and that runs 9psi due to free flow panel filter, no other engine mods), and the other one had exhaust done, ran 8psi. The second one was a S2 sedan.
I havent driven a manual one yet, so cant comment on them.
Well my auto Stagea (RB25DET) ran 5lb and 7lb. Three suggestions for you:
1. [no cost solution] You can get 10psi by bypassing the solenoid altogether. Follow SK's directions and bore out the restrictor and you can get any psi you want (see post #40): http://www.skylinesaustralia.com/forums/Ja....html&st=20
or
2. [low cost solution $30 or so] get an RB20 actuator (they run 10psi)
and or
3. [From $200 - jaycar eibc plus hand controller like mine or up to $1000 for flash big name one] Get an electronic boost controller (not a bleed type which will be little better than #1 above) to build boost more quickly and hold it longer.
So does that mean there's no 2nd stage boost for an auto? My auto car hits ~5psi fairly quickly with just a bit of lead foot from standstill.
I have never fully floored it so I (never revved over 4,500 rpm) don't know if there is the 2nd stage boost or not, where it hits ~7psi.
thats good info( i didnt know about the no - cost option)
With the RB20 actuator, is that 10psi with the rb25 boost controller or iwith a direct connection to the inlet nipple???
thank for the info
or
and or
    • I'm not sure the diode only will give the desired result. I'd probably approach it with a couple of relays (And you still might need a diode too!). You need to be able to break the constant feed from the headlight to the orange corner globe when the indicator is flashing. Not knowing which Skyline we're talking about specifically here too (And it may not matter, but I don't know the R34 column switches) you'd likely need to rewire the stalk, so that the indicator power itself no longer runs through the stalk too, as now you need it able to trigger a relay that will break the constant supply from the headlights to the indicator, then you'll need a separate relay to trigger the indicators to come on (Replacing the internal action of the indicator stalk).
    • Weird story from me My Toyota 86 was with Commbank comprehensive but for market value (who they use to underwrite is unknown) When I munted it beyond financially viable repair in 2020, rear end smashed in to the point it bent the rear quarter and roof, they knew I paid $31k cash for it because I told them, they still paid me out $38k, as all the 2017 limited edition variants with typical Km and condition were going for between $36-41k, so they did weird math and came up with $38k I never officially mentioned any of the mods that I had done, but as they were not the cause of the crash they were not fussed at all, the insurance inspector actually asked if I wanted to replace all the mods with the OEM stuff if I still had it laying around before they took the car I still came out of it behind though, because I had probably dropped $20k in it with the suspension (bent after the prang), wheels (bent as well) and "other" mods, that the inspector asked about But still, as the market value was higher than what I initially paid, and they paid out market value To say I was surprised with the outcome would be an understatement  Weird, but true, but probably just lucky with the inspector on the day I guess  Sadly, I don't think if I munted the old NC1 MX5 I would get the same result Meh, pay to play
    • Well, the car is back, all straight and shiny, for how long for is anyone's guess  After picking it up we went for a bit of a drive, Jebus I really enjoy driving this little thing, hopefully the weather let's us go for a nice long cruise this weekend as it will be out of my hands for at least a few days next week when it heads back into Mania on Monday It's weird, whilst I do always enjoy going for a drive, the NC makes me feel like a kid who has just got his first car, and they just want to drive wherever and whenever they can I really need to look into the MX5 Club of NSW
    • wow that is some seriously JDM original credibility there!
    • Selling hks rb25 cast manifold and waste gate.   Never going to use as don't have Rb powered car  Unknown condition of waste gate diaphragm  $900 Pick up only Ipswich Qld
