Ok, time to part out my car, been tryin to sell for 7 k whole but now i think its time to share its fruit around.
So heres the list
HKS GT2530 turbo and lines - $1,100
Hybrid front mount intercooler - $500
Standard Air flow meter - $100
Stainless steel intake pipe - $30
ISC coilovers - $800
Front Adj. Camber arms - $100 pair
Rear Adj. Camber arms - $100 pair
Adj. Castor rods ( one bent) - $50
HKS external wastegate with screamer pipe - $ 500
DBA slotted and drilled rotors in Very good condition - $500 for all 4
ceramic track brake pads - $100 for all.
Tomei 2 way diff - $800
oil catch can with lines - $ 40
ADjustable fule pressure reg. -$ 90
front seats - $100 per seat
Late model headlights - $200 each
All parts are still on the car so keep that in mind.
PM me for any other stuff that you may want or need.
or call or msg me on 0405 300 245
Cheers, Josh.
Edited by R32z all da way
https://www.sau.com.au/forums/topic/271523-parting-out-my-r32/
any chance of a pic of the front headlights/indicator??
hey bud not gona bother with a pic of the headlights, they are imaculate late model ones, someone said they looked like GTR ones but who knows, 300 bucks for both headlights and both indicators. cheers
  • 2 months later...
Appologies for not keeping this thread up to date!!
Only things i have left are
Front bar $ 200
Rear bar $ 100 as a few scratches
Reo bar $50
tail lights $150 for pair
boot lid, no spoiler holes. $ 180
bonnet $200
one headlight $90
passenger seat $ 50
rear seat $100 (seat base and upright section)
both doors with trims , Passenger side is damaged from accident. $ 150 for good one, $ 50 for damaged one.
need all these parts gone asap, need to put a car in the garage :)
msg or call 0405 300 245 is best way to contact me.
cheers.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
