Ok, time to part out my car, been tryin to sell for 7 k whole but now i think its time to share its fruit around.
So heres the list
HKS GT2530 turbo and lines - $1,100
Hybrid front mount intercooler - $500
Standard Air flow meter - $100
Stainless steel intake pipe - $30
ISC coilovers - $800
Front Adj. Camber arms - $100 pair
Rear Adj. Camber arms - $100 pair
Adj. Castor rods ( one bent) - $50
HKS external wastegate with screamer pipe - $ 500
DBA slotted and drilled rotors in Very good condition - $500 for all 4
ceramic track brake pads - $100 for all.
Tomei 2 way diff - $800
oil catch can with lines - $ 40
ADjustable fule pressure reg. -$ 90
front seats - $100 per seat
Late model headlights - $200 each
All parts are still on the car so keep that in mind.
PM me for any other stuff that you may want or need.
or call or msg me on 0405 300 245
Cheers, Josh.
Edited by R32z all da way
https://www.sau.com.au/forums/topic/271523-parting-out-my-r32/
  one.etik said:
any chance of a pic of the front headlights/indicator??
hey bud not gona bother with a pic of the headlights, they are imaculate late model ones, someone said they looked like GTR ones but who knows, 300 bucks for both headlights and both indicators. cheers
  • 2 months later...
Appologies for not keeping this thread up to date!!
Only things i have left are
Front bar $ 200
Rear bar $ 100 as a few scratches
Reo bar $50
tail lights $150 for pair
boot lid, no spoiler holes. $ 180
bonnet $200
one headlight $90
passenger seat $ 50
rear seat $100 (seat base and upright section)
both doors with trims , Passenger side is damaged from accident. $ 150 for good one, $ 50 for damaged one.
need all these parts gone asap, need to put a car in the garage :)
msg or call 0405 300 245 is best way to contact me.
cheers.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
