Lads,
Had my ECU remapped my Toshi today.
Easily the best $500 bucks ive spent in a long long time. Its a rare event for me when i drive away from something genuinely thinking i got my moneys worth. This time its without question.
Toshi spent much of his sunday tuning my car until i was happy, explained every part of the process clearly and kept me completely involved. The car is absolutely flying and i couldnt be happier. His focused attitude and attention to detail was second to none, this was very apparent especially after dealing with peanut after peanut mechanic (and twice the cash) who obviously had no idea.
Id strongly recommend his services to anyone. He clearly knows his stuff, and takes the time to do it properly. Pretty bloody rare (and valuable) in my book. Ill take the car nowhere else.
Thanks again Toshi, we will speak soon about the intercooler etc.
Cheers,
Matt
https://www.sau.com.au/forums/topic/271544-r33-gts25t-ecu-remap-by-toshi/
  • Replies 43
Thanks for yesterday Mattw_83
Feel free to contact me anytime if you have any problems.
Lads,
Cheers,
Matt
Yep he was good to me too. I got 190rwkw on 11psi R33 with std turbo but full exhaust etc.
Mine even was a bit strange with s1 ECU but s2 car and we did it via mail but he was very good, answered a lot of questions from me too. Definitely one of the best guys I've dealt with about Skylines.
If I lived in Sydney I'd just see him for servicing and everything.
Edited by simpletool
I have a r33 gtst with the mods below, do you think Toshi could hook me up. I would like to run 18 psi of boost on c16 fuel. Oh one problem I live in the Bahamas.
Mods:
FMIC
GREDDY PLENUM INTAKE
Q45 THROTTLE BODY
550CC INJECTORS
TOP MOUNT GT35R GARRETT TURBO
ACT STAGE THREE CLUTCH
TAIL BOV AND WASTGATE
STRAIGHT CATBACK EXHAUST
NISMO REGULATOR
HKS CONE FILTER
Thanks
UPDATED POST : I have a r33 gtst with the mods below, do you think Toshi could hook me up. I would like to run 18 psi of boost on c16 fuel. Oh one problem I live in the Bahamas.
Mods:
FMIC
Q45 THROTTLE BODY
550CC INJECTORS
NISMO REGULATOR
HKS CONE FILTER
Z32 MAF
Thanks
Edited by BahamaSky
I have an R33 GTS-t 96, with:
FMIC
3" Exaust (pretty Sure)
Pod (Enclosed)
Manual boost control (not sure if it works)
Rest is stock
Just wondering can i remap my standard ECU?
If so, what gains would i get?
How much would this cost?
also looking at installing a Auto Boost Controller to run 10psi, is it better to do this first?
Cheers
Cam
Thanks simpletool , stenve and Tangles.
I appreciated your thread!
Hi Cam84
I am able to remap std ecu.
Im not too sure how much gain but normally 185- 200kw.
Please check out this is thread.
http://www.skylinesaustralia.com/forums/Re...ml&hl=toshi
Hi Cam84
Toshi what about me any help for me I don't want an aftermarket ecu!
My thing is there is no one here in the bahamas that does good tuning, as a matter of fact we don't even have a dyno here. That is why I wanted an ecu tuned for my mods and from the threads i have read Toshi is the man. So I want him to tune my ecu.
Problem with your situation is that the tune wont be perfect and would need to be touched up a little bit anyway.
Or this is what he said to me when i enquired about getting one to NZ. Its impossible for him to tune perfectly it to your atmospheric conditions, if you know what i mean.
You need wideband A/F meter and some tools for check ping (eg; S-AFC2).
This is minimum tools.
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
