R33 Gts25t - Ecu Remap By Toshi
Lads,
Had my ECU remapped my Toshi today.
Easily the best $500 bucks ive spent in a long long time. Its a rare event for me when i drive away from something genuinely thinking i got my moneys worth. This time its without question.
Toshi spent much of his sunday tuning my car until i was happy, explained every part of the process clearly and kept me completely involved. The car is absolutely flying and i couldnt be happier. His focused attitude and attention to detail was second to none, this was very apparent especially after dealing with peanut after peanut mechanic (and twice the cash) who obviously had no idea.
Id strongly recommend his services to anyone. He clearly knows his stuff, and takes the time to do it properly. Pretty bloody rare (and valuable) in my book. Ill take the car nowhere else.
Thanks again Toshi, we will speak soon about the intercooler etc.
Cheers,
Matt
  • Replies 43
Thanks for yesterday Mattw_83
Feel free to contact me anytime if you have any problems.
Lads,
Cheers,
Matt
Yep he was good to me too. I got 190rwkw on 11psi R33 with std turbo but full exhaust etc.
Mine even was a bit strange with s1 ECU but s2 car and we did it via mail but he was very good, answered a lot of questions from me too. Definitely one of the best guys I've dealt with about Skylines.
If I lived in Sydney I'd just see him for servicing and everything.
Edited by simpletool
yeah great guy, had my s2 ecu remapped by him through mail also.
had a few hiccups but was more than helpful everytime i called him and everything was perfect in the end.
I have a r33 gtst with the mods below, do you think Toshi could hook me up. I would like to run 18 psi of boost on c16 fuel. Oh one problem I live in the Bahamas.
Mods:
FMIC
GREDDY PLENUM INTAKE
Q45 THROTTLE BODY
550CC INJECTORS
TOP MOUNT GT35R GARRETT TURBO
ACT STAGE THREE CLUTCH
TAIL BOV AND WASTGATE
STRAIGHT CATBACK EXHAUST
NISMO REGULATOR
HKS CONE FILTER
Thanks
UPDATED POST : I have a r33 gtst with the mods below, do you think Toshi could hook me up. I would like to run 18 psi of boost on c16 fuel. Oh one problem I live in the Bahamas.
Mods:
FMIC
Q45 THROTTLE BODY
550CC INJECTORS
NISMO REGULATOR
HKS CONE FILTER
Z32 MAF
Thanks
Edited by BahamaSky
Those are some serious mods!
Your best bet is to go full after market ECU and get some local to tune it.
These remaps suit more to guys with standard to hi flow turbos that have the "standard" modification
I have an R33 GTS-t 96, with:
FMIC
3" Exaust (pretty Sure)
Pod (Enclosed)
Manual boost control (not sure if it works)
Rest is stock
Just wondering can i remap my standard ECU?
If so, what gains would i get?
How much would this cost?
also looking at installing a Auto Boost Controller to run 10psi, is it better to do this first?
Cheers
Cam
Thanks simpletool , stenve and Tangles.
I appreciated your thread!
Hi Cam84
I am able to remap std ecu.
Im not too sure how much gain but normally 185- 200kw.
Please check out this is thread.
http://www.skylinesaustralia.com/forums/Re...ml&hl=toshi
Toshi what about me any help for me I don't want an aftermarket ecu!
My thing is there is no one here in the bahamas that does good tuning, as a matter of fact we don't even have a dyno here. That is why I wanted an ecu tuned for my mods and from the threads i have read Toshi is the man. So I want him to tune my ecu.
Problem with your situation is that the tune wont be perfect and would need to be touched up a little bit anyway.
Or this is what he said to me when i enquired about getting one to NZ. Its impossible for him to tune perfectly it to your atmospheric conditions, if you know what i mean.
You need wideband A/F meter and some tools for check ping (eg; S-AFC2).
This is minimum tools.
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
