Anyone remember this?
http://www.skylinesaustralia.com/forums/Do...l=don&st=20
Well, it's been 6months, and I finally have my license back.
33 is long gone, but I'll be thrilled just to get out in my parent's Terios.
Gonna test drive a few cars I've had my eye on this week too.
https://www.sau.com.au/forums/topic/271557-only-two-more-hours/
What cars do you have in mind? :)
Well, since my P's were reset and I'm forced to drive an NA for 3 more years (thankfully no red plates) I'm prob going to get an NA Supra, or NA R34 Coupe.
Gonna drive like a grandma too, not that you have much choice in an NA.
nice work :) supras are that little bit more expensive but nice cars
hey n/a's arn't that bad! i suprised a few people this weekend at deca with mine, too bad i was still the only n/a there hehe :D need to get some more n/a's at the events next time cmon beau and kieran :)
i want a r32 N/A . . .. but are hard to find for a decent price
Woo! Got it back.
Took the Terios out for a spin, but that car really such a let down. I have no intention to do any sort of spirited driving, but the Terios has the most sensitive clutch, has absolutely no guts and feels like it'll tip over if you take a corner at more than 20kph.
Still, it's good to be out and about again.
would someone really bother upping the engine in a 32 if you were not going to put a turbo in? I know it would be an improvement but if you were spending that much to upgrade your cars output I would imagine a turbo would be done too??
Late model 32 GTS's came with a 25 in it from the factory. And you'd be surprised the difference, given the weight of a 32, and the extra 80nm of Torque from the 25 over the 20.
I'd be tempted to spend the extra coin and go for a manual NA supra, the 3L in it is still deceptively quick.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
