I was going to use them for my project car, but need the cash for other mods first...
Were off a porsche cayenne turbo and are made by brembo...
come with pair of calipers, and 99% new pads... take 353mm Discs...
You cannot get better brakes than this..
These are pretty much NEW! they have done under 300kms on the porsche...
They retail for around the $7-8k mark...
Looking for around the $1800 mark as i just need the cash...
Have the discs off the porsche as well... 353mm drilled rotors with a stud pattern of 5x120 i think... which is porsche only... but if u want them, they're yours... throw them in with the brakes...
The size of these things is stupid... would make an awesome addition to a powerful car...
Also, located in Capalaba, Brisbane. Prefer not to post, as these things are HEAVY!
Contact me on 0402.022.582 preferably by sms, if you're interested...
Thats also a 12" sub box in the pic... For size comparison
https://www.sau.com.au/forums/topic/271564-fs-porsche-brembo-6-piston-brakes/
Sorry for the delay... net has been capped...
For those that requested... pics of the back of the brakes....
For those of you in another state... im not really looking to go through the drama of posting... rather cash in hand, etc.... much simpler and everybody is happy... been ripped off before with posting goods...
Nice Brakes :)
OS30GK - i don't think the process is hard, just the possibility of problems, missing items etc etc..
MYF70 :thumbsup: hi sam.
I see you round.
Posting with insurance and all should protect you sam.
Will consider posting interstate if the buyer agrees to transfer the $$ to my account, then once payment recieved, will send them... or COD at buyers expense... have been caught before using other methods... not negotiable...
postage to WA from here is around the $50 for calipers alone....not including insurance... well thats what aus post tells me
Owgasm: Not for a while mate... had the FTO off the road for 6 months while i get some 850cc injectors into it and a stronger up pipe.... (blew a hole outthe old one when we last hit the strip...)
Jap_Muscle:
Would not be direct bolt ons to any vehicle... The stud pattern is porsche only... calipers are huge and will require fitment.. was quoted $300 for fitment to my FTO... but that was just an over the phone guess... could be more, could be less...
These brakes are not for your run of the mill gtst.... these are made for high horsepower cars... anything under 300kws and they're overkill...
Edited by turbofto
really nice brakes mate. How large of wheels do I need?! Really want to see it on my 34. Anyone knows how to?
had been thinking to put porsche brake on my previous Audi TT. but too much brake force for that car.
btw, I guess they should be 5x112...Porsche, Merc, new Audi PCD
5x120 for BMW
Ah yeh, vincent, i think you're right... 5x112... i think i got mixed up...
Should fit under a set of 18s... forged 17s maybe....
If you need to find out any more specs, i think they came off a 2006 Porsche Cayenne Turbo
well i just finished my rb26/30 setup so im pumping about 400rwkw out of my gtt. so i do need th brakes.
if anyone can help me out on how to fit these babies that be great. im currently running 10x9.5 +22 Volk GTCs face 2
THanks
Edited by Jap_Muscle
THanks
these brakes will not fit on 18's unless u stick to 355mm rotors and under. i have the same brakes with 376mm rotors but my wheels are 19x10.5'
Edited by MR33
Sorry wat I meant was I have 19x9.5 plus 22 offset
Would they fit?
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
