Yes,They made for R33/R34 GTR Z32 afm
The kit Come with
2x Air Filter Adaptors
8x bolts for AFMs
4x Forged Pipes
2x Aluminum Pipes
1x Bracket Set
6x Straight Silicone Joiners
12x Hose Clamps
1x 1.5m Stainless Steel AN6 Mesh Hose Kit (for relocation of power steering pump)
would the pipes fit a r33gtr and are they made form the same materials? as greddy?
Cusco Oil catch kit -----------------------$100 delivered
Any pics of this please? I'd appreciate some :cheers:
Also - would you be willing to post to Melbourne?
Thanks!
    • you can enter your VIN (the original, japanese one) here to find the correct part#: https://www.amayama.com/en/genuine-catalogs/nissan however, after all this time it is more likely to be a wiring issue than the sender
    • no, it was the same here, just flurries but no need to get the toboggan out....but it is exactly the sort of days where its good to have some inside jobs on the list. Speaking of which the fuga is driving properly after 2 1/2 years.....but that is a whole other thread
    • And yes, put in the restrictor while you are there; a standard engine is fine with a little less oil and you are less likely to run out of oil if you have sustained high revs for any reason eg visit a track one day. How did you clean the cooling system
    • I didn't think about how a circle works before, dumb.  Before, I had .9mm restrictor bolts but I can't use these cause they were shorter aluminium bolts that just tear off their threads when tightening since the OEM lines are thicker than the shitty braided one that was installed previously. Now I use longer 1mm stainless steel restrictor bolts. I think the difference will not affect the health of the turbos, but I guess I'll have to drill out the main feed bolt as I agree multiple restrictions sound dodgy. The one that was installed with the braided line was just too short, but completely without a restrictive hole.
