Ok so we probably agree the rear end takes a bit of getting used to.
i've not even taken delivery of the car yet and i want it cleaned up and looking a bit nicer.
Looking at wing options, Highway Dolphin looks a bit excessive, Masa's wing looks like it may be a winner, tho i also like what i think is the stock item? but cant find many photos of it?
Masa
Are there any others out there that look similar? and dont look too much over the top?
I think they both sit a little bit too high :)
i like how the masa one is lower,
but keep em coming, there is actually a dolphin one in silver on Yahoo at the moment.. was considering it for 300 or so delivered.
Is larger than the Nismo one.
Here are a couple;
Balsinari
Pond
I have also seen a little black spoiler that would be no higher than 15mm and looks like it is an OE part of the rear door (it isn't).
Edited by iamhe77
rofl, so i take it thats not one of their wings
go on the yahoo auctions (or via IM) and check the masa stuff on there, it looks different. its a pity the wings are around $700+commission+delivery blah blah
Yeah, I'm very familiar with yahoo japan :D probably spent a years salary on it over the years..
i really dont like their actual wing. i think its Pond's for sure.. but i want the one on the masa car..
As for other things going on, R34 Gtr wheels will be going on, along with an exhaust prob a custom job done by my friends @ Westside in Padstow, Sydney
got a few Interior parts on yahoo already few things broken in the car that need replacing
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
