Just had my O2 sensors replaced and my R32 GTR runs much better!
During cruise and light throttle the car is more responsive and quieter! I no longer have to down shift to go up small grades and the fuel economy is better. I should have done it sooner!
About a month ago I took my car out to Hills Motorsports to have them run it on the dyno. Before we started, they hooked up the diagnostic tool and found my rear O2 sensor was dead, and the front was not responding very well. At R32 GTR owners know, the Titania sensors are expensive. I shopped around and found Kudos Motorsports had the best price on 2 new sensors. I gave them my info and received the O2 sensors within a few days. I took my car back out to Hills Motorsports and they installed them for me. Driving away from the shop I noticed an immediate improvement in the throttle response during light throttle. A side note, the black on the back of my white car from the exhaust has reduced considerably.
Thanks Hills Motorsports and Kudos Motorsports! I would recommend using both of these businesses!
https://www.sau.com.au/forums/topic/271646-o2-sensors-replaced/
To talk the the factory ECU you need a CONSULT cable and software for your laptop. It will show what the sensors are displaying and from that you can deduce their condition. I have the PLMS consult cable. It works.
http://www.plmsdevelopments.com/consult_if.shtml
yup, i have the consult cable + software but didnt check o2 sensors prior to swapping to PFC, do u know if PFC picks up faulty sensors at all?
Check paulr33's PFC faq;
http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm
I haven't checked the km's per tank yet... I do know that from Tuesday to Tuesday the petrol gage is down on empty. This week it is on a quarter tank. (Not scientific, I know.) The exhaust sound was louder and you could tell it was rich. Now it runs smoother and the exhaust note is crisper. On any slight uphill I would have to down shift. Now it has some power down low so you can just push on the accelerator a little and it picks up speed. My wife even noticed the difference!
The change is significant if your O2 sensors are bad. Because they are so expensive, have them checked first!
Mark out at Hills Motorsports in Castle Hill is very good.
  • 1 month later...
i've been fairly interested in this thread.
My O2 sensors on my 32 GTR went bust when my turbo blew and obsiously broke the sensor.
since then i got the turbos replaced to new ones, which are the 2860-5's and because the sensor was buggered the car would run like a real pig when they were plugged in. so i unplugged them. then a week later i spun a bearing!
i know bad luck hey!
since that i got a motor rebuild, forgies, new crank, race bearings, thicker head gasket,etc
but didnt replace the O2 sensors, they've only gotten installed today, but for about a month of not having them plugged in on the new motor the car has been runing fine.
getting around 15L/100km which isnt too bad, but that has been conservative driving.
going to pick it up today,
will post again to let you guys know if i notice any difference.
You can even use a O2 Sensor to test it..
On a cruise in 5th gear doing around 60km/h A/F ratio should be near stoich (14.7) as the closed loop circuitry should trim the fuel down so it leans out, if it's running HEAPS rich you know your O2 is dead.
PFC users
ETC, SENSOR SW CHECK
look at 02-1 and 02-2
these are your 02 sensors
they should blip up and down when you tap the throttle
if they are toast they will show 0.00 or hardly move
and the sensor name may become highlighted in black background if its shagged/unplugged
the O2 sensors didnt make much difference to overall power, but it definitely does feel a lot nicer to cruise around.
my fuel ecconomy has improved heaps too, i did a bit of a country drive on the weekend and i've still got a 1/4 left in the tank (yes, i know its a guage reading which isnt accurate at all) but i've done 450+ kms
before i would struggle to get 400kms out of a full tank, i know the country drive would've helped.
the car seems to be a little more responsive at low revs too when its off boost.
just feels and sounds more crisp
i got genuine ones, and i'd say they're well worth the money!
i dont think my mechanic took too long to do it?
he didnt charge me any labour though, because it was supposed to be done with my build but the sensors didnt come in.
i would assume it would be a bit of a pain, just like doing most work in the cramped engine bay of a GTR.
i think you might need a special tool to be able to undo it?
not 100% sure??
Brez
they shouldn't alter power output.
there is a special tool, 02 sensor removal tool
its bascially an open ended socket so you can slide it over the sensor and it doesnt clash with the plug
i think its about $30 from repco, without it = dont bother
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
