Hey guys got a 99 model wrx wrc blue in colour fairly standard apart from cat back exhaust, cars in good nick apart from some paint fade on the bonnet isnt too bad got 242,000k's on the clock rego till end of jan nxt yr also willing to trade for another import must be turbo and not front wheel drive you can pm me or contact me on 0432018314 via sms located in s.e. melb.
$12,000ono
https://www.sau.com.au/forums/topic/271676-subaru-wrx/
yer i kno its got heaps of k's original engine the previous owner just used it as a daily run around he clocked up most of the k's on it ive never had any problems with the car ive owned it for around a year now i just miss having a coupe :S
https://www.sau.com.au/forums/topic/271676-subaru-wrx/#findComment-4633431
  • 6 months later...
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
