In the past week or so the front right cv boot on the stag has split. As its only just recently happened its making a hell of a mess on the backside of the weel and under and around it all.
How hard are they to change? Ive been told buy Xmetal N15 pulsar boots fit, can anyone confirm this? Can some one give me a how to change it? Its on the RSfour stagea.
Also some tips on doing cheffs 260 stag would be helpfull cos both of his have been gone for a while now and if its a diy well do his soon too ;)
https://www.sau.com.au/forums/topic/271687-changing-cv-outer-boot/
Ive changed all mine but then realised i didnt to the ties up tight enough and now i have grease all under my car.
Its pretty easy to do, Wheel off, Middle nut out, losen end of drive shaft and take it out. A rattle gun is very handy to use also.
Also once u got it off take it to the C.V joint and drive shaft place in edwardstown, same rd as doyle crash but closer to south rd. They are roughly $15bucks each with grease.
Could work. Might be able to leave the rotor on and handbrake and undo it that way. Only one way to find out i guess.
Mines 4wd to, shouldnt make any difference. Just do the end ties on the boots up tight.
shit never really looked at that its a gt -4 ! lol sorry mate!
Hand break wont d oa thing cos its the fronts :P ... just get someone to stamp on the pedal :cheers:
havnt seen you out it a while how ya been anyway?
mayeb i will have a go myself... thought it could be tricky... gues I shouild be able to tackle most things after taking both turbos of adams 26! f**k doing that ever again.
if the boot has split and most of the grease is out DONT just put another boot on it chances are water/grime has already got into the joint and will still stuff up, better of hitting up S.A suspension in pooraka and getting a bearing kit done with new boot! just not worth all the effort for it to stuff up in a couple months!
yeah ive got some prices and cheapest by far is 85 at some place down in Lonsdale. Not close but its a fair bit cheaper.
If lukes done all his 4 ill have a look at it tomorrow morning and see what i think.
my front left is going.
boostworx will do it for $120
actually booking in now
  • 1 year later...
Digging up an old thread here. I've done the rightfront drive shaft inner boot on my R33 GTR. I rang SA suspension and they only had a part number for an R32. My question...... Do the R32 and R33 GTR's use the same boot. If anyone knows for sure and it is the same, I can buy the boot and do the job over Easter, otherwise I have to take the shaft out to try and find a match.
Thanks.
  • 2 years later...
Hi, i know this is an old thread, but i thought id try m luck.
I have recently had a split boot on my rear cv outer joint.
I have new boots and was gonna do both sides my self.
How hard is the job?
My car is a skyline R34 GTT
Any answers would be great, thanks
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
