Yo!
Well, most of us would change engine oil a fair bit, and maybe after a couple track days etc, but how often would you change brake fluid and give it a flush?
Im talking more cars used for track days etc here,
Would you say, do it same time as doing engine oil change?
say after 3 track days or so?
more or less?
cheers!
chris
https://www.sau.com.au/forums/topic/271688-how-often-to-change-brake-fluid/
Brake fluid should be fine unless it's old or you've boiled it IMO.. doesn't need doing as often as engine oil but if you gave it a quick bleed every oil change then you'd be sorted. That'll keep the fluid moving through the lines enough that a full flush isn't necessary, if you regularly track it.
I think I did my brakes about a year ago, did a wakie day today and my coolant temp started moving before I had brake problems.. although the brakes were spongy after sitting in the pits they were fine after 1 pump once i got back in ;)
DOT 3 Should be changed every year DOT 4 every two years this is under normal driving conditions, as other have said if you get brake fade/boil the brake fluid change it as you lowering boiling temp of fluid. once you boil brake fluid its useless.
i've been doing mine before every track day lately, though not by choice. Stupid leaky rear caliper....
Normally i'd do it every 3 months or so with motul rbf600 or penrite sin.
I tend to look at this sort of stuff in terms of money it costs me if i don't do it. 20 bucks spent every 2nd or 3rd day vs losing track time which roughly works out at around 400/day for me inc entry, travel and trailer hire.
I don't think there is necessarily a golden rule. It's all about how the peddle feels. Environmental factors as well as how hard you brake on the track will determine how long it lasts. If the the peddle ain't solid anymore... New fluid time.
With my track abilities (hah which ain't that amazing) every couple of track days is so fine. But if its just street driving well over a year should be fine even with cheap fluid.
Cheers
Cam
I just run the good stuff through.
Cheap stuff is shit, no better than 3 day old rbf 600 if any gets left in the lines.
Just run it through until you see clean fluid come out the other end and you'll get 99% of the old stuff out.
every 12 months at most, unless you manage to boil it - if you do change it straight away.
unfortunately the better quality the fluid, the more water it absorbs, so the more often you have to change it. cheaper stuff might last a couple of years in the average mum's camry
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
