Getting some dinner sunday night in malaga, saw all the lights had to go check it out, *edit* driver came flying round the corner, 350 was parked on the side of the road, and the 4wd has hit another car and smashed into the 350 pushing it up over the kerb snapping the rims bodykit and squishing it against the tree, i was there when the *edit* guy came out n saw his 350, poor bloke lol
edited - no need to mention the nationality.
amazing how the 4wd stayed upright in its position, couldnt get pics from other side cause of the cops but this is what i did get
https://www.sau.com.au/forums/topic/271722-350z-got-wasted/
Man I hate that mentality^
Not aimed at you R34P3R, but it's shit that a generalisation can be made about a race only if you are a member of that race. The statement and communicated/intended message is the same...yet the only difference is the person who said it. I'm not Asian (well technically 1/8th Chinese but whatever) and I still say there are a truckload of bad Asian drivers out there in Western countries...it's a widely known and accepted consensus. But whatever, some days you can drive on the road and feel like the only good driver is yourself lol.
https://www.sau.com.au/forums/topic/271722-350z-got-wasted/#findComment-4616562
LOL well I did just get off a 12 month option notice, so I guess according to the law I am a bad driver (albeit much more law abiding these days). But I consider carelessness and not concentrating like the above far more dangerous than doing several lots of 6km/h over the speed limit whilst being aware of your surroundings and vehicle capabilities.
https://www.sau.com.au/forums/topic/271722-350z-got-wasted/#findComment-4616983
This is exactly why race does not need to be mentioned in posts.
Anymore and warnings will be handed out.
https://www.sau.com.au/forums/topic/271722-350z-got-wasted/#findComment-4617346
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
