Ouch... More delays, huh? :starwars:
Oh, I'm seeing Falcons in that Breeze colour everywhere now!
+1
Had a mate roll up in his XR6t yesterday... couldn't help but think "Yup. An R34 front-ended C34 will look ace in that colour"
ah that sucks to hear mate, there are no doubt places that rent out booths to use over your way? i know there are some over here
There is only 2 hire booths in Brisbane. $90-100 per hour plus bake time. So by the time you roll in, mask up and paint and bake it is around 4-5 hours :( Plus the painters cost
Worked on the car all weekend, meet with the painter/mate yesterday arvo everything was planned to paint it today. Get a text this morning at 6.20am, sorry mate can not do. I was furious :)
Spoke with my brother in law today who is a panel beater. His painter is going to do it this Sunday for $200. He sounds cheap, but he painted a mustang recently which got voted Australia's best. So it should could up great if my prep work is any good. Fingers crossed. :)
Fitted new sydneykids bilsteins today. The rear can only go to 340mm, they hit the tyres. Have 5 more grooves to go. The fronts have a few more grooves to go but the bottom platform hits the suspension arms, even after putting a 4mm deep groove in the bottom spring platform.
Should just leave the boody thing standard!!
Looking at new wheels. I am a bit over the R34 rims
Maybe these in 19x8.5 or 19x9's
These are 3 peice that way I can play around with offsets and not have to use spacers on the front.
With the R34 front being wider, I need to run approx 20mm wider offset than the rears to fill the guards.
With a type A or B disk upfront and C disk on the rear, should be able to keep the same dish F & R
Was thinking gold Rays GT-c's but the price is up around $4500 for rims :P
^^^ i do love the look of black wheels but am of the opinion that if you are going to spend the big dollars on gorgeous wheels (the 2 option you posted are prime examples) why would you want to hide them by blacking them out?
I agree!
If we were all made of money, how about Volk RE30's or CE28N's? Those would be my two picks.
I am a lover of 2/3 peice rims. Does not matter too much on center colour, but need the polished rim whit as much dish as possible.
That is why I am looking at modular wheels so I can get my offsets right.
I think most have seen my previous R33, ford blueprint with gold rims. plus 15 years ago ta22 celica in ford everglad green with gold B45's in a massive 15x6 with 195 tyres. That was huge back then LOL
Would also like a set of Duluck six spokes, but they have stopped making them
Picked up a pair of EVO 8 Recaro's yesterday for the fronts.
Just need to make them fit the bride rails.
Will be using series 2 manual back seat and door trims I have lying around.
    • Nah its a server spammer thing  Although, now that I manually approve all the accounts I can probably loosen up some of the restrictions.
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
    • Thanks buddy. I thought it was a server storage thing. 馃ぃ
    • Perfect! Thanks for this, both look like great options!
