hey stageatype S....i was wondering where did you end up buying your front quarter panels on your car from? because i found the masa motorsport R34 conversion, but they dont have your quarter panels.
I order them direct from Masa in Japan.
If you are in OZ, I organised copies to be made. Contact CCubed in Sydney for them, they own the moulds. Aprrox 600-650 pair
Do not buy any of the cheap copies of ebay extra
What other Masa parts have you found, as most of the other bits need are genuine R34 gtr
Since my thread has been bumped, a bit of an update
Currently working on the car every night tring to get it finished for a drag day on the 29th May
I have a list of over 20-25 items still need to be done, some alot bigger then others.
Hopefully get the final engine work done this week, modify exhaust and fmic piping next week and then on the dyno the following week.
Plus supsension and brake work as well.
No pic's, you will have to wait until it is all done
Will you have the FFP installed? I got my batteries yesterday and am fitting them now. Very happy I did not have to move washer bottle.
Plenum is bolted up. vac lines done. Still need to throttle body and cable and fit injectors.
A couple pic's of engine and rebuilt rear calipers went on tonight. Will do the front and bleed as well tonight
sorry crappy iphone pic's
All mechanical work is know done with a couple of minor things getting finished off at the tuners. Dropped the car off last Friday after inishing at 2.30am in the morning tring to get it all done, and will be on the rollers tomorrow.
Will be picked up Wednesday arvo if all goes well.
Still have to refit the front guards, bonnet, head lights and front bar before Saturday.
Running it down the strip at Willowbank for a couple of hours to see what it can do.
Can't wait!!!!!!!!!!!
where did you end up taking it to get tuned darrin? hopefully you don't have the same boost creep problem i was having on the gcg dump.
EFI Performance
Not shaw how it will go. I had it at the exhaust shop last Wednesday for 7-8 hours getting the exhuast to fit (it was bent is 3 places) plus intercooler piping changes to suit turbo and inlet plenum.
I ended up with a HKS silent cat back which 3 inch with a canon on the rear and a large centre resinator. The problem with that is the resinator only has approx a 2 1/2 pipe thru the middle, so that may restrict it a little.
Are you free Saturday arvo?
EFI Performance
what power level are you hoping for?
i have a HKS system but the 409 not the silent, i think they are the same just one is shinny stainless. i never looked down the centre muffler, i bet its the same to :cheers: . though mine seems to flow good enough. i'm blaming the split dump for the creep, i opened up the wastegate pipe entry at the flange and it helped. still get the occasional spike. think i may mod it to be a bellmouth.
yeah i should be free, i haven't made any plans as of yet. why's that?
Edited by QWK32
i have a HKS system but the 409 not the silent, i think they are the same just one is shinny stainless. i never looked down the centre muffler, i bet its the same to :D . though mine seems to flow good enough. i'm blaming the split dump for the creep, i opened up the wastegate pipe entry at the flange and it helped. still get the occasional spike. think i may mod it to be a bellmouth.
It has enough bolt on's to get to 300rwkw, as long as there is no issues
Will have to wait and see. Will be limited to stock head gasket, so 18-19psi
Sat arvo QLD SAU drag day. I think I get 1 free passenger entry included. My son is going, under 13 are free. Otherwise $20 to watch.
The car is now running and ready to go on the dyno
Has not been run for over 7-8 months
Very excited :rofl2:
let us know how it goes mate, i'm keen to see the results. i'll let you know if i'm going to head out on saturday, i don't mind paying the spectator fee if i have to. hopefully 2 hours is enough to get a few runs in.
heres the wheels i have used on my stag, dont comment on height lol, i kno it needs to be lower, but its for sale so dont think ill bother
cx7 wheels, need massive spacers to get flush, so didnt bother
weds sport wheels, 17x9+18 just sit out of guards
Edited by sheepus
Should be picking it up this arvo if there are no issues. Not sure if I will get much work done tonight on it, State of Origin is on (Go Queensland)
Will get the full front on Thursday night, drive to it work on Friday, 75km round trip and then race Saturday. Hopefully
Put the new wheels on the other day, 19x9.5 +12 but they are B disk and they clear the r34 calpiers by about 1mm!!!
Grabbed some 3mm spacers yesterday just to be sure.
If it had r33 calipers, they would have not fitted.
Don't use crappy Chinese copy parts!!!!
The hks copy fuel rail is still leaking, now around the fuel entry
They are going to remove it from the car as it is not square on the ends and the screw in fittings are not sealling. Need to mill the end square
First few power runs were seeing over 200rwkw's at 14psi when rail was leaking.
After bagging doggy chinese stuff, I need to kick my own rear end
Due to running out of time getting the piping done, I made a very doggy BOV return line from high pressure PVC pipe to "just get the car going"
The tuner stopped due to worring about it blowing apart on the dyno.
So I will be picking up a new metal pipe from the exhuast shop tonight as well as picking up the car.
Will have to remain as is until next week when I can get it back on the dyno.
Anyway it is making 330rwhp (246rwkw) at only 15psi.
Tuner advised it was still making easy power and should get to the magic 400rwhp figure I want.
    • Oh bugger ! Your right ! Good old hydrogen sulfide. Takes me back to the good old school days !
    • I've owned a few scooters over the years, a Vespa PX oil burner was my first scooter, followed by a few others, including a little 50cc BeeWee that I used as a barracks bike, and I've had a blast on all of them, they really are the cheapest for of city/suburb transport around The only issue with scooters in Australia is lots of people look down on them due to their size,  maybe they need a big bike to make up for something else where they are lacking, unlike Europe and Asia where every man an their dog owns one, and now that filtering is legal in NSW, local traffic is never a issue Not to say I haven't owned my share of big cc bikes over the years, but they were for more blasting through the hills or Hwy riding where it needed to sit on Hwy speeds Safety wise, I ride like everyone is always trying to kill me, everyone is running a red, or running stop/give way signs, or generally asleep at the wheel, which most people are duringtheir commute, I also ride really safe, and give myself, and everyone else enough room in case I need to pull some hasty evasive actions, I've done a few rider training days over the years, which has come in handy on more than a few occasions  As for mods, there's nothing really, and yes your right about aftermarket exhaust, all you get is loud and obnoxious noises from them, like every 250-300 cc you hear with a aftermarket muffler, in saying this I did put a rear muffler from a 125 Aprilla on one of my old 125 scooters, it was horrendous and no amount of full face helmet and ear plugs would dampen that noise As for coming from the Harley, and what a overpriced POS that was, I no longer do big rides as my poor old busted joints ache after about 1/2 an hour of riding, long cruises are so much more enjoyable now in a car, so a big bike would be pointless
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
