the car tuned for 360kw on 1.5bar, top end of afr is 12, than the car shut down for half hour and run on the dyno again. without tune the top end of afr become 12.8. and tuner can't go any lower, because its runing out of the fuel pump. but before break is fine??
because the afr is too lean, so we drop the boost to 1.4bar on road. no idea about the afr, but tuner said it will be safe on 1.4bar. the knock is all good. no higher than 14.
anyone know the reason???
i got a nismo intank fuel pump.
https://www.sau.com.au/forums/topic/271778-big-afr-different-in-one-hour/
before you start the run, check MONITOR, 2 CHANNEL, AIRTEMP, WATERTEMP
check the water temp and air temp when you get normal AFR
then turn car off
and check do your dyno run an hour later
compare, if they are different by a fair bit, the PFC will add in correction,
ie: it might be richening up or leaning out, based around temps you are seeing after 1 hour of not running
I would be highly suspect on the turbosmart fuel pressure regulator - they are absolute crap.
I have had issues with three of them on two different cars I have tuned. An example was an XR6T making 750rwhp on about 25psi of boost; so 4bar base pressure and another 25psi on top of that means total fuel rail pressure of 84psi. What happen was that the rail pressure started not rising 1:1 with boost. Pull the regulator apart to find that the dodgy copper to aluminimum face they use to regualte pressure had started to etch lines across the face - hence not sealing properly. Its not even a proper ball valve. We replaced the reg with another brand new item only to find after about 10 more runs the same thing started to happen.
The other issue I had was with the click type ones on a sierra cosworth. Not sure what the issue was but when it started leaking from the vacuum source - I pulled the pin!
12.8 on a rock solid tune may be fine, but if it goes from 12 to 12.8 and the tuner is out of room for adjustment then there are some serious issues that need to be addressed, especially the "out of room for adjustment" part. Who's to say whatever is at its limit has a lazy day one day and then you're at 13.5:1 or worse.
Yes that is a bit lean...
Although it depends if were talking about a forged or standard engine.
Definately not safe for a standard engine making that much power...
Try a SARD reg. Top quality product.
not safe for a forged engine either
I already older a sard one, hope this one is working. and i don't think the problem is the fuel pump.
because it was working fine on 1.3 bar,(AFR is about 11.5) and still some room to adjust. no point run out of the fuel pump if only add 3 or 4psi. and even stay on 1.3bar its still leaner than before.
Edited by Nosure
umm, if your fuel pump is maxing out, couldn't it just be getting leaner because you are pushing it so hard that it is dying? my suggestion would be to scrap the fuel pressure reg and get a new fuel pump.
you say that you don't think the fuel pump is fine, but you said in your first post that the tuner said you can't make it any richer because of the fuel pump. and in your last post you also talk about maxing the fuel pump.
you are running your pump at it's max, or very close to it and i'd guess it is slowly dying.
yeah its possible, but the the fuel pump was ok last time on dyno,(about 2 or 3week ago) the afr still adjustable on 1.3bar. and afr is 11.5.
this time's tune is also ok before break, the afr:12, but after the break the car run on the same dyno again, the afr is go up to almost 13.
confusing.
something else i just thought of, how old is your fuel filter? highly unlikely it would make a difference such a short time, but you never know.
i don't know. but my car is almost done 50000kms. and nismo fuel pump maybe done about 30000kms.
not very old.
normaly if the cat shut down half hour, the fuel pump and fuel etc`` should cooler, and afr should getting richer. but no idea why its getting leaner. i guess because the fuel pressure changed.
Some engines will run fine at 12.8. low boost engines with short blocks ie: v8's and 4 cyls with same head and block material il: both alloy.
there are a lot of cars that are tuned this lean porka cup cars are an example.
6cly engines with cast iron blocks that cool poorly in the rear 2 cyl's running high boost and agressive timing are NOT the right engines to be running such lean AFR's on, the egt's will be to high and they will be prone to detonation.
really high hp RB's should not be leaner than 12:1
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
