  • Replies 97
Posted Images
PM sent... let us know if you still need something printed out. (I'm sure Brendan (being as organised as he is :whistling:) will have some copies on Sunday anyway).
Edited by 32godzilla
PM sent... let us know if you still need something printed out. (I'm sure Brendan (being as organised as he is :whistling: ) will have some copies on Sunday anyway).
Cheers for that mate, i'll print it out just in case.
im bringing my 31..so im sure your 32 is more than welcome......plus..I HAVE BRAKES!!!! for the first time in 2 years i have a decent pedal...i dont have to pump the brakes to get something happening..which is good cos i dont want to hit anyone :)
i dont want to hit anyone ;)
Fills me with confidence..... maybe if we could have all the 'lines at the back seeing this is a stag cruise. Stags, followed by luke cos he's also in a family car like us :) then the 'lines.
Skylines dont seem to be too welcomed on a Stagea cruise that was organized on a Skyline forum ;)
maybe they want the public and Police to think they are Volvo's and not figure out they are Skylines in disguise? :)
Edited by dark.sky
1x 31 (hole in fuel tank.... nasty... hope all is ok ?)
1x 34 (beaut)
15x Stagea's
was just a drive, a cefiro would have enjoyed the roads as much as the Stags did.
will arrange a cruise thru the Northern and Eastern Hills Ranges soon...... :) closer to town for the northeners
chain of ponds, lobethal, handorf, echunga, strath, callington, mt lofty, etc
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
